The tablet wont let me access "Hungry Shark Evolution" after it has been installed for approxiamately 2 weeks. Game worked properly until I was unable to go in to it, it said "app is not installed". Tried to download again but said that there is no external storage. What happened to the internal SD card that is included in the tablet?
SOURCE: SD card capacity
Yes, the hardware is SDHC-compatible. You just need to apply Microsoft hotfix KB934428 for Windows XP (http://www.microsoft.com/downloads/details.aspx?displaylang=de&FamilyID=6edfb30f-b1ab-42a8-a330-acd6762961bc) and you are set. 16GB SDHC working like a charm.
Stefan
SOURCE: Fujitsu Internal Wireless card on Tablet ST4121 not working
the internal wireless card is very likely to be soldered on the board and then you probably cannot swap it by yourself, you can buy an external one(like an expresscard one) ore have the one on-board swapped by Fujitsu(with or without warranty coverage.)
please rate.
SOURCE: Cannot access Appslib app library
I couldn't either! So, I uninstalled the appslib and reinstalled it and it works great now! You have to reset everything and you will lose apps I guess if you have any, I had none so this didn't affect me. If you go to Coby's website and under FAQ's it explains how to uninstall and install. Good luck!
SOURCE: I try to download apps
First, you must be on android 2.2 or higher to do this. You can download the update here: http://www.archos.com/support/support_tech/updates.html?country=us&lang=en
Next, once you have the new firmware, you go to the applications menu in settings. Once there, select a program you would like to move to the sd card and in that menu press the move to sd card button.
SOURCE: I cannot access all my
The first step would be to do a hard reset from the settings menu. Many people also have luck with the K-9 email app in the Android Market.
