Springe loader fell out of model while reloading need to fix
SOURCE: Swingline Stapler Staples Only After You Open It Up....
When you lift up the top of the stapler (as though you are going to put staples in), does the pusher slide freely back and forth? It might be getting stuck at some point and not pushing the staples (either due to a worn pusher spring, or friction). First (after removing the staples) try spraying some light oil on the mechanism and lifting the top part of the stapler up and down a few times and observe how easily it moves back and forth. Also, with the top open try GENTLY sliding back and forth a little - if it slides fine with no sticking, try loading staples and using stapler. If it slides ok, but doesn't quickly return to it's "normal position" when pulled so as to put tension on the spring, rhen the spring may be worn and need replacing.
SOURCE: Hi, can you supply me with the inner handle spring
Take stapler to local hardware store for replacement.
SOURCE: There is a Stanley bostitch model B2000 stapler in
The person that asked this is probably long gone, but in case anyone else comes across this... I had the exact same problem when I dropped this same stapler today and the spring came out. After examining it for a bit, I realized where the spring had to go and fixed it.
Open the stapler the same way you would as if you were replacing the staples and look at the top piece, towards the back. There will be an elongated black hook here to attach one end of the spring. The trick is where you route the spring after that... look towards the front end of the same top piece, and you'll see 2 holes in the metal. You need to push the spring up through the first hole, then pull it back down through the second hole (you may want to use a straightened paper clip to snag the spring so you can pull it through that second one), and only then do you attach the other end of the spring to the hook in the sliding metal piece that advances the staples in the staple holder.
And that's it!
