Personally I'd flash it. I think you've got something corrupted in your system and its being triggered when you attempt to access the browser. Alternatively you can try downloading a different browser (http://www.4shared.com/android/ki088UbS/Dolphin_Browser_v200.htm) click download now wait the 20 seconds and an apk will show up for you to install. You will have to set your reader to accept outside downloads its in settings. Yea other than that do a full flash. Go to the support section of the cruz website and you'll be following the process for upgrading the firmware.
good luck
Go to Settings, from your pull down notifications bar or in the app drawer. Find and tap on Application Manager,(Apps or Applications, if different on your specific device). When you land in the Applications Manager, swipe right to left to get to All Applications and then look for Download Manager and tap it to open (this is the app with the Android as a logo). Press disable, then enable it once again. Hope this helps!
FIXED ! Well almost... This problem is happening with the 'old' Android devices; Software if changing every day and most of the updates are barely tested on all devices and Android versions. The spyware, malaware, adware, are then becoming day after day more aggresive and sophisticated. So, the clean solution if format/clean/reinstall Original software, no updates.
Another helpful hint is clean all software cache, saved data, for each application , one by one, and then...
install Avast antivirus free and block behaviours, "APP LOCKING" option, at least of "Play Store" and "Downloads".
You won't see anymore the annoying message, and device will work like a charm.
Thank you, Bye. FIXED !
