Nokia N95 Cellular Phone Logo
Posted on May 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Its tuning on an off by its self
My phone is turning off an on
HeLpINHaRrY
Level 2:
  • Expert 210 Answers
  • Posted on May 19, 2009
HeLpINHaRrY
Expert
Level 2:
Answers
210
Questions
0
Helped
45024
Points
708
Goto nokia webiste and download the latest software ,if that does not work you should restore to factory defaults.
it was a common problem with the earlier phones and is sometimes caused by the applications you have installed on it .
2answers
If I don't have the remote, how do I scan for channels? I moved to a different location. Is there a way to get to a menu?
most modern tvs are self tuning if turned on for the first time.so turn tv on,then find the up/down buttons on the outside,and select auto tune
2answers
Why itunes keep poping on my iphone when i turn it on
on ur pc when u open itunes it has option when phone connect open i tune by it self just untick that
My envy 3 powers down every time i go to vzw tones deluxe im am now on my replacement phone whitch is doing the same exact thing i go to vzw tunes and the phone turns off then turns its self back on.
I have the same problem with my samsung alais 2, and it just started happing, I didn't know if some how it got blocked or something, So if you find an answer that would be great, sorry for wasting your time and question.
Oct 25, 2010 • Cell Phones
1helpful
1helpful
Stereo not working, and slidind doors either. need fuse diagram
Visual Inspection Chart Mechanical Electrical
  • Audio unit
  • Digital audio compact disc changer
  • Antenna and two-piece antenna cable or electric antenna
  • Radio speakers mounting/speaker cones
  • Capacitive suppression bond wire and radio receiver hood bonding strap
  • Central junction box (CJB) fuse:
    • 6 (15A)
    • 2 (25A)
  • Ignition switch
  • Circuitry
  • Audio unit
  • Video system
Audio Unit Self-Diagnostic Mode
NOTE: To enter the speaker walk-around test or audio unit self-diagnostic mode, the audio unit must be turned on and in radio tuner mode (AM/FM).
  1. To enter the following tests, depress the desired preset button while in the speaker walk-around test or while in the audio unit self-diagnostic mode.
  1. To exit the audio unit self-diagnostic mode, turn the ignition switch or the audio unit off.
  1. If the concern remains and the fault is not detected, proceed to the Symptom Chart to continue diagnostics.
  1. The audio unit self-diagnostic mode has five tests available:
    • Preset button 1 = Audio internal/external SELF TEST. This test is an on-demand self-test. If SELF FAIL is displayed, press TUNE > to scroll view the DTCs stored. Refer to the audio unit Diagnostic Trouble Code (DTC) Index. If the system is OK, SELF PASS will be displayed.
    • Preset button 2 = View/clear continuous DTCs. NO DTCS is displayed if no DTCs are retrieved. If DTCS FOUND is displayed, press TUNE > to view the DTCs retrieved. Refer to the audio unit Diagnostic Trouble Code (DTC) Index. To clear all DTCs, press the EJECT button. DTCS CLEAR will be displayed.
    • Preset button 3 = SIGNAL TEST. This test measures the average strength at the current tuner setting.
    • NOTE: Always DOCUMENT, CLEAR and CARRY OUT the audio unit on-demand self-test again.
      Preset button 4 = Software configuration level. This test queries each audio unit system controller for its software configuration level. SOFT LEVELS will be displayed upon completion of the query. Press TUNE > to scroll view the software configuration version level.
    • Preset button 5 = DISPLAY TEST. This test will light all the audio unit display segments for five seconds. When the test is complete, DISPLAY TEST is displayed on the bezel.
1helpful
Unknown Phone on Lincoln Navigator
It means your phone is activated somehow. Cellular Phone NOTE: The audio system does not operate when the portable cellular phone is in use because the audio-mute feature will mute the audio system when a call is placed or received. Portable Cellular Phone Features
The portable cellular phone system is available only with the P100i audio unit and has the following features:
  • hands-free operation
  • radio muting while phone is in use
  • radio displays the phone number, signal strength, and call timer
  • radio can be used to dial stored numbers and adjust hands-free operation volume
For more detailed information, refer to the User's Guide.
  • Entering ACM Self-Diagnostic Mode.
  • ACM (Audio Control Module) Self-Diagnostic Mode
    NOTE: To enter the Speaker Walk-Around Test or ACM self-diagnostic mode, the ACM must be turned on and in radio tuner mode (AM/FM).
    ACM self-diagnostic mode can only be entered while in the Speaker Walk-Around Test.
    1. To enter the Speaker Walk-Around Test, press the ACM Preset Buttons 3 and 6 simultaneously.
    1. The Speaker Walk-Around Test stops at each speaker and applies a different tone to each speaker for about 1-2 seconds. Each speaker is tested and displayed on the ACM in the following sequence: RF, LF, LR, RR, SUBWOOFER I, SUBWOOFER II.
    1. The Speaker Walk-Around Test automatically continues and tests:
    • the antenna and displays ANTENNA II, for five seconds.
    • for a speaker short. If a short is present, SPKR SHORT will be displayed.
    • for the CD/DJ. The ACM display will show NO DJ if not present. The Speaker Walk-Around Test will end and the ACM will return to its previous setting.
    1. ACM self-diagnostic mode has five tests available:
    • Preset button 1 = Audio internal/external SELF TEST. If SELF FAIL is displayed, press TUNE > to scroll view the DTCs stored. Refer to the ACM Diagnostic Trouble Codes (DTC) Index. If the system is OK, SELF PASS is displayed.
    • Preset button 2 = View/Clear continuous diagnostic trouble codes (DTCs). NO DTCS is displayed if no DTCs are retrieved. If DTCS FOUND is displayed, press TUNE > button to view the DTCs retrieved. Refer to the ACM DTC Index. To clear all DTCs, press the EJECT button. DTCS CLEAR will be displayed.
    • Preset button 4 = Software configuration level. This test queries each radio system controller for the software configuration level. SOFT LEVELS will be displayed upon completion of the query. Press TUNE > to scroll view the software configuration version level.
    Controller Description Radio Display Example Main Main micro software version MAIN ##.##.## CDSP CDSP micro software version CDSP ##.##.## ADSP ADSP micro software version ADSP ##.##.## Auxiliary Auxiliary software version AUX ##.##.## CD/DJ CDDJ software version DJ ##.##.## CD Changer CDR software version CD ##.##.## Tape Deck Tape Deck software version TAP ##.##.## RSC Rear Seat controller software version RCP ##.##.##
    • Preset button 5 = DISPLAY TEST. This test will light all the ACM display segments for five seconds, then turn all segments off. When the test is complete, DISPLAY TEST is displayed on the bezel.
    1. To enter these tests, press the preset button desired while in the Speaker Walk-Around Test. This will abort the Speaker Walk-Around Test and start the selected test.
    1. To exit ACM self-diagnostic mode, turn the ignition switch or ACM OFF.
    1. If the concern remains and the fault is not detected, proceed to Symptom Chart to continue diagnostics.
    the module is under the floor console. Do you have the phone user manual.
    Radio won't pick up any stations on samsung u600
    make surre that you have your handfree pluged into your phone as this acts like an antena. then go options and self tuning, that will then search for radio stations and you will get a list of them. all you have to do when you get a list if radio stations is click on one.
    I would like to remove the opening ring tone from new phone
    Go to phone settings under ringing tune u we see welcoming tune off tune that where u will set it
    Top Nokia Cell Phones Experts
    Kolbrun...
    Muhammad Irshad...
    Muhammad Irshad...
