I have no idea how to open my cd/disc drive on my gateway ne57202h. I tried going into the settings but I got nothing. PLEASE HELP!!
SOURCE: I got a cd stuck in the cd/dvd drive for my
All CDs & DVDs have a tiny hole on the drive tray.
Get a paper clip, straighten the paper clip and insert it into this hole and push the paper clip in gently, the tray will release and pop out, then you can remove your disc.
You can do this without the laptop being powered up or powered down.
SOURCE: My cd rom drive will not recognize any cds or
When I had my problem, no cd was recognized, music or data. But when I paced a dvd movie in there, and started up my PowerDVD, it would play just fine. I ended up replacing the drive. In fact, I got an upgrade because the first one was CDRW/DVD-ROM, and now its a DVD burner. 86 bucks including shipping.
SOURCE: CD/DVD rom drive not working
Hi there.
It sounds like the drivers could be bad or the lens has gone.
This can be a common problem with vista loosing the CD/DVD drives.
Do
this >>>>>> right click on "computer" and select
"manage" from the sub menu, then select "device manager" from the left
hand side, it will generate a list of devices, look down the list for
CD/DVD and click on the + icon next to it, from the drop down list
right click and uninstall, restart the PC and let vista re-install the
drivers for you, then try to use the CD/DVD.
If this does not work please post back.
Good luck and thanks for using FixYa!!
The CD/DVD drive may need reseating to make proper electrical connection. Remove this drive and insert it back into the laptop.
Next try cleanibg the drive.
The laser lens maybe dirty, use a CD/DVD lens cleaning kit to clean the lens int the drive.
If this does not fix your problem then the CD/DVD drive is faulty and needs to be replaced.
