Unless Shark says water only I don't think that would be a problem. All the vinegar will do is remove any grease on the floor and perhaps remove some bad odor. I rinse my hair with vinegar water every day after shampoo and conditioner. Only then do I consider my baby fine hair clean!
1. Put minced scallions and chopped mushrooms in bowl. 2. Add red wine vinegar. 3. Add ground beef to bowl. 4. Mix everything together with your hands. 5. Flatten the beef into four patties that are 1/2-inch thick and 5 inches in diameter.
Cook Patties
1. Set stove-top grill or burner to medium-high. 2. Preheat nonstick frying pan. The pan is the correct temperature when a drop of water dances on its surface rather than sticking to it. 3. Place patties in the pan and cook for 2 to 3 minutes. 4. Flip patties and cook for another minute, and then add sliced cheese to the tops of patties if desired. 5. Cover pan and allow burgers to cook for a final 2 minutes. Cook 3 to 4 minutes for well-done burgers. 6. Remove hamburgers from pan and place in hamburger buns. 7. Add condiments and toppings such as ketchup, mustard, sliced tomatoes, lettuce, red onions and pickles.
Share some please! ü
Thank youfor visiting FixYa! We answer yourconcerns promptly for FREE. Please spare a few seconds toclick on YES button in return. Havea good one!
You didn't give a model number so I'll tell you both methods. The F5xxx and F6xxx models have a cap at the top of the clean water tank that doubles as a measuring cup. The cap is about 3 inches in diameter. Fill the cap to the fill line with shampoo and dump it in the tank. Then fill the tank with hot (Not Boiling) water.
The F7xxx series has a 2 section tank. The large section is for hot (Not Boiling) water. The smaller section is for shampoo. Fill the smaller section with shampoo and the Steam Vac will mix the water and shampoo for you in the proper proportion.
Please let me know the model number from the data plate.
It is likely started with the letter "H", followed by at least for numbers.
It will allow me to post the User Manual to you.
The cleaner goes into the small bottom at the very rear of the machine. It is uses full strenght (don't add any water to it). You add clean water into the bottom clear plastic section on the front of the machine. The clean water bladder is soft plastic and it is filled from the top. When you start using the machine, the dirty water will get suctioned into the section surrounding this bladder. The machine will stop working when either the bladder is empty or the dirty water section is full. Remove the entire plastic section to dump out the dirty water.
I had the same problem with mine and it was an easy fix. If you remove the soap holder without putting the selector dial to "water only" you will lose the prime in the hose that goes to the water chamber. It takes a few minutes of pulling the water trigger to regain that prime, but it will come back eventually. Easiest fix, of course, is to always remember to dial to water only when you need to add cleaning solution..
Usually when you can't put out soap, there is a problem with the vale at the bottom of the dispenser, or the seal is not on it and gone or sitting in the hole, needs to be on the dispenser. Same is true for the wter tank valve and seal.
I solved the problem, the metal (hot!) release rod gets stuck & needs a little push.
Unfasten the top by prying off the rubber gasket after removing the top. Remove the 2 small phillips screws, then remove the front that holds the nozzle, & remove those 2 phillips screws.
Carefully pry up the top with a putty knife, inside you will see the tip of a metal piston that the plastic release knob is supposed to contact. Set it on its front, & soak the piston with a light household or sewing oil, giving it a few taps with a blunt object occassionaly to loosen, heat up & test before reassembling, but remember, the piston is very hot. When you push on the piston with a screwdriver, it should release the steam, but also stop when you let go. Work with it a little & it will come back to life.
