We have model CRE9400CCM electric range and the F7 code just started flashing. how can I fix this problem? It's also kicking out a breaker if other appliances are on.
The "F7" fault code could mean a stuck or shorted key pad/console or it could mean a failed oven control board. There is no way to reset the control.
A service technician would determine if the problem is with Key Panel/Console or the Oven Control by: See image below.
NOTE
: This is intended for the service technician. I do not recommend attempting to diagnose which one has failed. This test must be performed while connected to the power supply.
I recommend calling a service technician to diagnose and repair your range
My 20 year old electric Jenn Air range recently flashed the F7 error code and beeped repeatedly. I shut off the circuit breaker until it cooled. The next day I turned it on and everything seemed fine. We baked a pizza and the erro repeated when the oven was shut off. I opened the front panel and noticed the wire ribbon connecting the front panel to the display was slightly askew. How that happened is beyond me. I pulled out the ribbon hold down clips, pushed the ribbon in all the way, and replaced the hold down clips. The range is now working properly after replacing nothing. The cheapest fix possible.
Jun 23, 2007 - The error code "F7" will be displayed along with a beeping sound if the ERC (Electronic ... We have a GE Spectra Oven - GAS - we keep getting F7 errorcodes and the oven will not heat. ... In my case it was the keypad.
Apr 6, 2010 - Get shopping advice from experts, friends and the community! I was boiling water on back burner of ceramic stove top GE range Model ... When anyappliance picks up an error code or starts beeping the problem that caused it ...
Typically error code F7 indicates that your Frigidaire range is experiencing a failure with either the potentiometer or UIB (User Interface Board). Let's try resetting you range by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. It is best to wait approximately ten minutes and then turn on your appliance. If the error code persists, it would be advisable to contact an experienced appliance repair tech to assist further.
The code is because of bad keypad/the control panel.Have it changed.It probably non-functional and constant beeping sound is followed as you mentioned.Theres a link to explain more about this for reference.The only solution is to replace the control panel.
I have a jenn air SVE47600F.It just started beeping and giving a code 7.None of the controls work when it brings the code up,but controls work fine when code is not there. We have to turn the breaker off to reset it.Sometimes when we have been gone all day we'll come home and the range will be beeping and flashing a code 7
F7 stuck keypad Stuck keypad may mean relay is turned on. Determine if problem is with the Key Panel or Control by: 1. Pushing CLEAR/OFF pad. 2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
