Cars & Trucks Logo
s
shayne saylor Posted on Dec 20, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1994 350 chevy diagram firing order whereis number 1 on the cap
Jerome Minks
Level 3:
  • Chevrolet Master 3,103 Answers
  • Posted on Dec 21, 2013
Jerome Minks
Chevrolet Master
Level 3:
Answers
3103
Questions
0
Helped
672446
Points
9361
Dont go by that..do this.. bring the 1 cylinder to top dead center by matching the timing marks on the engine..then take off the cap.. look at where the rotor is facing..thats your 1 plug spot..then the rest follow one at a time all around the top of the cap..1-8-4-3-6-5-7-2..
3 Related Answers
Anonymous
  • Posted on Nov 30, 2008
SOURCE: distributor cap firing order 1993 chevy cheyenne truck v6
Firing order is 1-6-5-4-3-2 cyls. # 1-3-5 on drivers side front to back and cyls. # 2-4-6 passenger side front to back.
tbirdfan1
Michael Thomas
  • 3056 Answers
  • Posted on Jan 09, 2010
SOURCE: need firing order diagram for 91 s10 blazer
991 Chevy S10 firing order
The firing order for a Chevy s10 depends on which engine you have.
1.9L engine the firing order is: 1-3-4-2 . Distributor rotates counterclockwise.
2.0L engine the firing order is: 1-3-4-2 . Distributor rotates clockwise.
2.5L engine the firing order is: 1-3-4-2 . Distributor rotates clockwise.
2.8L engine the firing order is: 1-2-3-4-5-6 . Distributor rotates clockwise.
4.3L engine the firing order is: 1-6-5-4-3-2 . Distributor rotates clockwise.
Anonymous
  • Posted on Mar 05, 2011
SOURCE: 4.3 L vortec firing orcer and wiring diagram
need firing order for a 95 chevy 4.3 vortic engine thank you
2answers
Firing order 96 chevy cheyenne and how do you tell which is number one on distributor? Thanks :)
I've uploaded a diagram that gives you the firing order for the 96 Chevy Cheyenne. The best way to find out which is number one in the firing order is to following the spark plug on the engine block back to the distributor cap. Number 1 is on the right side, closest to the front of the engine. Best of luck!
2helpful
3answers
1995 chevy impala caprice classic lt1 how to install new plug wires dont no firing order
the firing order is 1-8-4-3-6-5-7-2. The Left side of the distrubuter 1-3-5-7 and Right side of the distributer is 2-4-6-8.
Need a spark plug firing order diagram for 1990 chevy s-10 blazer 4.3l
Firing order is 1-6-5-4-3-2. Cylinder numbers are, front to rear: left side (driver) 1,3,5, right side 2.4,6. Distributer numbers are: 1 in front side of cap. numbers run clockwise same as firing order from number one position.
11helpful
2answers
Firing order diagram 1994 chevy 454
Here is the diagram. The white circle in the distributor cap is number one plug wire location, rotoation is clockwise
12helpful
3answers
Firing order on a 305 on the cap. Got the wires all messed up...
This method is good for the firing order on all chevy small block v8 engines from 265 cubic inches to 400 cubic inches. This would include 265, 283, 305, 327, 350, 400 cu. in. chevy small block v8 engines.
Let's cover some safety concerns first. If you try to troubleshoot a mixed up firing order with the engine running, you could be in for a serious shock,.. literally. You can do it, with certain precautions, but you really don't need to check the firing order with the engine running. You definitely don't want to try checking the firing order if you are wearing any kind of pacemaker or sensitive electromechanical prosthesis. The voltage coming out of the ignition coil is in the thousands. Common sense dictates that you wouldn't stick a knife in an electrical outlet, so you wouldn't want to take chances with being shocked by the electrical discharge from your classic chevy's ignition coil either. See the diagram:
The firing order, which should be cast into the intake manifold, for the chevy small block V8 is 1-8-4-3-6-5-7-2. The firing order is the numerical sequence in which the spark plugs are fired. The insertion position of each spark plug wire around the circumference of the distributor cap can be found according to a clock face. The insertion sequence determines the firing order. The firing order is followed clockwise around the distributor cap starting from the 6:30 position with the 6:30 position being the number one cylinder spark plug wire.
On classic chevy small block engines that use ignition breaker points instead of electronic ignitions, the number one cylinder is the one immediately clockwise of the small metal sash cover on the distributor cap. The firing order starts here. There is no sash cover on the distributor cap for GM HEI electronic ignitions, and the firing order is the same, but starting at the 5:30 position.
The firing order makes sense if you know how the cylinders are numbered. The number one cylinder is the front most on the drivers side and 2 being the front most on the passenger side. From front to back, the cylinders are odd numbered on the drivers side, and even numbered on the passenger side.
Additional details HERE.
Hope helps (remmeber rated this).
9helpful
Need firing order diagram for 91 s10 blazer
2helpful
Need a 1988 454 chevy firing order wiring diagram
1-8-4-3-6-5-7-2 Number 1 should point toward number one cylinder and then go clockwise around the cap.
11helpful
3answers
you need the firing order?? it is 1, 6, 5, 4, 3, 2 clockwise. Number one on cap is forward position, or 6 o'clock position, just left of the hold down bolt.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
