The top will not go up or down. It worked for awhile, but yesterday when I was trying to lowere the top the electrical motor quit. There appears to be two wires running into the fuse box under the hood for this purpose. I do not have a tech manual covering the electrical system so I don't know if these wires are factory or something that was added. I just purchased this vehicle a few days ago from a private owner.
SOURCE: Hood won't open
is it cold where you are? it may be frozen open. pound on the front top of the hood a few times to see if it will pop up.
SOURCE: 2007 BMW X5 Fuse Box Locations & Fuse Diagrams ?
fuse 33 on the inside fuse box (there are two) should be the one you want.
Robert
SOURCE: 1989 BMW 325i my hood release is detached...how do
There is a small lever on the front of the grill--its black and you may not see it right off.
SOURCE: 96 bmw 328i convertible...Top wont
i have a 325i bmw convertible and by mistake i pulled the release bar under the back seat and detached the motor for the convertible and know it doesnt want to open or close the convertible
SOURCE: convertible top won't go down on my 1998 bmw 323ic
Sounds like the sensor has faulted or the pump has become disengaged. Usually when the light is flashing it's a sensor. You can check for a pinched line or low fluid also. There is a manual lock overide procedure to get the windows up, it's in you owners manual.
Good luck...i hope this helps,
