Frigidaire FAH106N1 Wall/Window Air Conditioner Logo
Posted on May 15, 2009
Electronic AC shuts down during power outage.
Trying to bypass the switch on an electronic window AC in a community cable building so when the power comes back on the AC will also come back on. If the power flickers or goes out the AC shuts down and has to be manually reset, if I could bypass the electric switch or ? to shut it off you unplug the cord.
Anonymous
Level 1:
Scholar:
  • Contributor 64 Answers
  • Posted on Sep 11, 2009
Anonymous
Contributor
Level 1:
Scholar:
Answers
64
Questions
0
Helped
16293
Points
68
When I read this...this only tells me that some people are only as bright as a 15 watt light bulb.
You know they have these things on there to keep you alive, instead of catching on fire and killing you with smoke.
Leave it alone and follow the directions. You will live longer.
1helpful
My Panasonic blu ray player goes back to standby mode ever time I try to start it, What should I do?
Hi Bruce
Most electronic equipment these days use a switch mode power supply, not the old transformer. This takes your AC 240/120 volt wall power to the necessary low DC voltages required by the actual electronic circuits.
They also have current sensors in case of circuit problems so that the shut down if a problem is sensed.
These switch mode supplies use a lot of Electrolytic Capacitors which are prone to age. They often Leak at the base or bulge at the top or even pop (blow).
If your up to it.... you could open up the box and check for leaky or blown Caps. They can be cheaply replaced with similar value devices. Take photo's before removal & beware of their polarity.
Obviously, if your not a technician, never work on a live switch mode circuit. You can get a nasty shock.
Good Luck
How to Replace an Electrolytic Capacitor
Capacitor Replacement Tutorial
How To Bypass fuse Or Fix Blu Ray Dvd Player No Power
3answers
Windows shutting down -not!
Which operating system are you running?
tip
Power Outages, what you need to know!
We have all had them, Power Outages, inconvenient, and also very deadly, well to Electronic equipment anyway. You see when any Circuit, is Made or Broken, at the instant of contact, when reconnecting, the current draw is considerable, also, after the connection has been made, and the "Load" being connected, and the Current draw is large, all sorts of transients, Spikes, Surges, Oscillations, is reflected, up and down the entire network. Now along with this, MOST people do NOT completely remove, the unit from the mains, by withdrawing the plug. nor, probably, even turn it off. This is wrong, ALL/ANY electronic equipment, that is connected to that Grid, will also encounter a phenomenon know as "Inrush Current" Now, this Inrush Current, Can and Does cause a great deal of damage to electronic equipment, the, instant reconnection, without going through an ON/OFF switch, and Power Conditioning Circuitry, well, the initial Current draw for that instant, is incredibly, high, and with nothing between, the current surges in, stressing everything, in the Power Supply, and more. Now along with that, you also have Transients, Spikes, Surges, Ringing, Oscillations, caused by the reconnecting of the Circuits. Joining of Cables, or Contacts. When the Power Goes OFF, you should NEVER leave anything plugged in after a Power outage, you need to withdraw each and every plug, from ALL Electronic equipment, note here, purely resistive, and relay type equipment is usually immune, it must be removed, and it shouldn't be reconnected, until about 5 minutes, AFTER the Power has been reconnected. This is to Avoid, all of the bad things that are caused by the reconnection back onto the Grid. If you do this, you can be assured of you Electronic items, lasting at least as long as they should, and not suffer premature deaths.
on Apr 22, 2010 • Computers & Internet
HOW TO LIGHT OVEN WITH A MATCH
Look up product manual on internet.
Look at label located inside oven door, and add .pdf to search parameter to help find manual.
Then read section about lighting appliance.
If power is out, then pilot will not have any gas >> if gas control is electronic.
Many electronic gas controls require electric power to operate circuit board.
In old days, you removed the bottom tray on oven to access burner and pilot orifice. Then you pushed down switch to release gas through pilot tube, and put lit match into the gas stream to light pilot. Hold down switch until pilot flame heated tip of thermocouple which caused magnetic switch to stay open inside gas control. Release switch and pilot stayed lit.
Safety concerns and vast advances in manufacturing cheapness have changed gas appliances so they are more inconvenient for do-it-yourselfers during ordinary power outage.
Cook hamburger over metal bucket with newspaper, and grease on newspaper burns enough to cook hamburger.
People always buy generators and flashlights, but nobody suggest buying barbeque briquets and starter fluid as way to keep warm and cook.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
I have a Utilitech In Wall Digital Timer Lowes Item #: 141224 | Model #: LW60418, purchased from Lowes. I've lost the instructions and can't figure out how to set the timer after a power...
Open following link for Utilitec timer manual:
http://waterheatertimer.org/Program-wire-Utilitec-LW60418.html
This timer should have a back-up capacitor so that programming is kept in memory during power outage.
Power outage is known cause of timer failure. When power turns on, the surge knocks out electronics.
People writing to fixya report electronic timers and electronic water heater controls stop working after power outage. Probably many other electronic devices are affected too, but that would be out of my specialty.
Troubleshoot says 'in case of operational failure, press reset button to clear all settings and restart.'
If timer has failed, buy another from Lowes and return defect in new package.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Our power shut off. AC window unit was on. When power came back on, AC said "E1" Unit model no. HWR08XC7
The "E1" Code indicates a security protection shut down code. Based o what you said about the power outage and the restoration of power, I assume the unit was left ON during the power out and restoration of power. A power surge more than likely caused the error code.
Hopefully irreparable did occur and you can get the electronics to reset by doing the following:
Turn the ON/OFF Switch to OFF and unplug the unit for 15 minutes. After that time has elapsed plug the unit in and turn the ON/OFF Switch to ON. Hopefully, the electronics reset & reverted back to the original factory settings and the error code has disappeared and you can set the controls as you like. If that didn't happen, you should contact Haier Customer Support 1-877-337-3639, as they can tell you which circuit was effected. From there, you can determine if a repair is warranted.
Hope this helped you and thanks for choosing FixYa.
No cover for fuse panel, need diagram please? need to locate cruise control fuse. Thank You!!
its the number 17 is for the spped control, electronic fuel gauge,electronic sppedometer, atc control, ac clutch, lamp outage, heater rear window, electronic blower spped controller
Dimmer Switch not working after power outage
It's quite probable these units have gone faulty, due to the "Outage" see my previous post below.. You will need to replace these units, to restore functions. Please, have a read below, it may save you many $$ We have all had them, Power Outages, inconvenient, and also very deadly, well to Electronic equipment anyway. You see when any Circuit, is Made or Broken, at the instant of contact, when reconnecting, the current draw is considerable, also, after the connection has been made, and the "Load" being connected, and the Current draw is large, all sorts of transients, Spikes, Surges, Oscillations, is reflected, up and down the entire network. Now along with this, MOST people do NOT completely remove, the unit from the mains, by withdrawing the plug. nor, probably, even turn it off. This is wrong, ALL/ANY electronic equipment, that is connected to that Grid, will also encounter a phenomenon know as "Inrush Current" Now, this Inrush Current, Can and Does cause a great deal of damage to electronic equipment, the, instant reconnection, without going through an ON/OFF switch, and Power Conditioning Circuitry, well, the initial Current draw for that instant, is incredibly, high, and with nothing between, the current surges in, stressing everything, in the Power Supply, and more. Now along with that, you also have Transients, Spikes, Surges, Ringing, Oscillations, caused by the reconnecting of the Circuits. Joining of Cables, or Contacts. When the Power Goes OFF, you should NEVER leave anything plugged in after a Power outage, you need to withdraw each and every plug, from ALL Electronic equipment, note here, purely resistive, and relay type equipment is usually immune, it must be removed, and it shouldn't be reconnected, until about 5 minutes, AFTER the Power has been reconnected. This is to Avoid, all of the bad things that are caused by the reconnection back onto the Grid. If you do this, you can be assured of you Electronic items, lasting at least as long as they should, and not suffer premature deaths.
What problems do these technologies solve in UPS?
1. Provide conditioned clean AC power to computers & other peripherals (except laser printers, which should not be powered by UPS).
2. Protect equipment from the harmful effects of brownouts & sags.
3. Supply power to equipment during a power outage for a specific time, either to allow for the graceful shut down of systems, or to keep the systems working during the power outage (depending on the battery capacity).
Top Frigidaire Heating & Cooling Experts
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
