Frigidaire FRS12PYS1 12000 BTU Split System Air Conditioner Logo
Question about Frigidaire FRS12PYS1 12000 BTU Split System Air Conditioner
What does H1 code indicate?
Posted by E Morin on
Frank Passarelli
    New Friend:
H1 on a Trane / Amanna mini split wall unit means its going thru its defrost cycle while your indoor unit is in the heating mode. Outside temps may just be too cold to constantly give you warm air. There is no supplemental heat with these units that i am aware of. The heating is not Electric its done with reversing the temperatures of the freon gas in the unit. Outdoor unit becomes a air conditioner while the indoor unit is the condensor.
Posted on Feb 10, 2016
Frigidaire
  • Official Brand Answer
  • 2,267 Answers
Hello E, I appreciate your post!
I see that your Frigidaire air conditioner is displaying an error code of "H1". I have reviewed the air conditioner and the "H1" error code could be an "HI". The "HI" error code means that the room temperature is above the display range. I would recommend performing a reset on your air conditioner. In order to reset the air conditioner you need to unplug the power cord you can press the reset button and then the test button that should restart your air conditioner. If that does correct your issue I would recommend seeking assistance from a professional technician for proper diagnosis and repair. I hope this information is helpful for you. -Matt
Posted on Jan 25, 2016
Frigidaire freezer has H1 error and is beeping and will not freeze
Typically, error code "HI" (the customer may say "H1") on a Frigidaire refrigeratorunit indicates that the unit has detected high temperature in the freezer and/or therefrigerator https://kb3.s2g.net/index.php?/article/AA-00411/0/Frigidaire-Refrigerator-Unit-Flashing-HI.html
How to remove H1 error in voltas AC?
It indicates a problem, what that is contained in the factory repair manual and meant for technicians. when the error has been been repaired the code will clear.
What does code h1 indicate?
H1 ie a HEATER fault, which usually occurs after the fill and just as the machine is about to start heating the water, when your machine detects that the heater has gone "open circuit" . This is probably a failed heating element(There is a break in the wire inside the element) . I can't be specific because you don't mention the model number, but washing machine heater elements are usually available on eBay or from your local white goods supplier fairly cheaply (You will need a model umber to make sure you get the correct one). Replacement is not too difficuly. There are many many YouTube videos available with instructions
What to do when h1 is flashed in ifb automatic front load washing machine
Cannot find anything about H1, but error code E01 is door not closed properly. An instrument at work sometimes reads "h1" and this indicates a "high" reading, but don't know if that is really relevant here. Sorry I can't help any further. Good luck.
ASKO TL751 error messages ?
Asko dryers as model T760 or T780 indicate failure by error message (like "Overflow", "Sensor", "Thermistor", ...) while the model TL751 indicate failure by error code ("H1", "H2", ...)
Below you can see a list of error codes:
H1 error - Humidity sensor error
H2 error - Drying temperature sensor open/short error
H5 error - Heater overheated (ELECTRIC TYPE)
Heater disconnection check and H4/H6 error (ELECTRIC TYPE)
H3 Error - Flame Detector Open Defect (Gas Type)
H7 Error - Gas Valve Defect or Gas Blocked-off (Gas Type)
H8 Error - Igniter Defect or Flame Detector Short (Gas Type)
Dado
WHAT FFHS2322MS H1?
Hello friend, thank you for your post!
I understand that your Frigidaire refrigerator is providing a "H1" error code. However, "H1" is an invalid code. I show a code for "HI" and that stands for high temperature in the freezer compartment. If you are receiving this error code but your temperature is cold inside your freezer it could be a miscommunication within the board and I would perform a reset on your appliance by flipping the household circuit breaker for ten minutes. I hope this helps. -Matt
Voltas ac vertis premium showing H1 Indication?
Voltas vertis premium display showing "en"
5helpful
2answers
Fridgeaire error code H1
Hello - Could it possibly be HI? Typically error code HI indicates that the unit has detected high temperature in freezer. Try setting the unit to a lower setting. Generally the factory setting is 0 for the freezer temperature and 37 for the fresh food temperature.
2helpful
H1 error code; what does that indicate?
H1 indicates the high limit switch has been tripped. Usually, only a temperature of 114 degrees will trip it or the switch itself may be bad. Depending on your setup, if you just have a normal mechanical time clock, you should have a fireman's switch wired in that will shut the heater off 15 minutes before the pump shuts off.
This can also be caused by a bad or improperly adjusted pressure switch. This can be tricky especially if the heater is installed below the pool water level. If you know that the heater has not tried to fire when the pump is off, then I would suspect the high limit switch has failed and needs replaced.
Top Frigidaire Heating & Cooling Experts
Robert
David Shaub
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
