1991 Chevrolet Corsica Logo
Posted on May 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Care runs really rough
My wife was driving home at 10:00pm hom from school and the car ran rough check engine light went on and died. then the next morning she went and got it and the car ran like it was brand knew. then we drove it all over ran threw a tank of gas then i took it to work and it did the same thing but aslong as i faned the gas peadel it final straight back out and ran fine then she took it to school and came home and it ran find to make a long story short is you can bearly go anywhere in it when it decieds to quit i checked the fuel pressure and at an ideal it runs at 39 and then when you rev the egine then it drops to around 30 and also when you first turn over the car it dosent have any pressuer for a few seconds any ideas please help me
  • lenhard901 May 22, 2009
    did that and got the egr valve replace nuttin still akso took it to a chevy dealr and they cant even figure it out they cant get it to do those syptoms
  • Anonymous May 11, 2010
    I saw that it was stated the check engine light came on have you had the codes checked and if so what were they.
Sam Challis
Level 2:
Sergeant:
  • Expert 177 Answers
  • Posted on May 15, 2009
Sam Challis
Expert
Level 2:
Sergeant:
Answers
177
Questions
Helped
51935
Points
623
Check the most common simple and cheap thing first, change the fuel filter.
N80 start
You have to find the reason the check engine light is on. This will aid in diagnostics. Also, are you buying fuel at the same place both times?
94 chevy astro rough idle and surge when driving
check throttle body and check for codes
I have a 1997 dodge avenger es 2.5 liter here's
Check the vacuum line on the fuel pressure regulator for any sign of gas being sucked into the line. A failed regulator will let extra gas get into the engine. If it's okay, have the fuel pressure checked. That's sure a lot of gas, way too much for the engine. Good luck.
3helpful
4answers
2helpful
3answers
2002 express 1500 van, will not start
remove dog house locate test port and install guage should be 45-60 psi
4answers
Car Won't run right and now not start
Check the gas it could be contaminated, Not to sould like a Wise guy but are you sude it 's not deisel fuel you put in.
03 Chevy Tahoe, ran a little rough, than check engine light came
when the check engine comes back on get it right to a computer at your local mechanic so you can tell what the problem is
98 Mercury Tracer starts missing and dies after 60 - 80 miles
U can go to any autozone, kragen or other chain auto parts stores and they will run the trouble code test for free, let me know what they find if anything, this also may be a fuel pressure problem
2001 Ford F-150
Overdrive light flashing is a warning to alert the driver there is a problem with the transmission . DTC'S - diagnostic trouble codes are stored in the transmission control module . Have it check !
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
