* Situate the printer so that you may clearly get to the back of the device. * Open the rear door path and check for the presence of any paper in the path there. * If none. Then you need to check the area around the fuser. * Permit the printer to cool for several minutes. * Release the side catches and open the top of the printer. * pull out the cartridge. * inspect the area around the fuser. You might see a paper jam there. Clear and reassemble.
I could provide you with written instructions to clear paper jam, however i thought it would be good to provide you with a link to solve it for better understanding.
Click on the link below and it will give you step by step instructions to clear a paper jam with video demonstration.
hi, troubleshoot with the printer troubleshoot utility in your OS. it should restore connectivity. try resetting the connection and settings for the printer using manual. otherwise, use the manual to re-install the device as this will also reset the connection. here's link to manual.(select the operating system and download the installation software)
