Seems like it is getting no fuel?
Run the fault codes first to check that the CPU is still operational as the power surge and extra high voltage may have damaged the CPU/ECM. IF good use the code reader to reset the CPU.. I hope that you replaced the prime reason for the battery failure. The alternator.
Testimonial: "Well the alternator is NOT bad, pulled and took it for testing, all good. Got it started with starter fluid but won't stay running, has to be a fuel thing?"
SOURCE: Diagnostic code P2299 for 2004 Dodge Ram 1500 5.7 hemi?
P2299-BRAKE PEDAL POSITION / ACCELERATOR PEDAL POSITION INCOMPATIBLE
Set Condition:
The PCM recognizes a brake application following the APPS showing a
fixed pedal opening. Temporary or permanent. Internally the PCM will
reduce throttle opening below driver demand. One trip fault and the
code will be set within 5 seconds. ETC light will illuminate, the light
will only stay illuminated while DTC is active.
Possible Causes
DRIVER PRESSING ACCELERATOR PEDAL, THEN PRESSING BRAKE PEDAL, AND CONTINUES TO HOLD THEM DOWN SIMULTANEOUSLY
STOP LAMP SWITCH
APP SENSOR
The most likely cause of this DTC is
Brake Torquing the engine by pressing the Accelerator pedal and the
pressing the Brake Pedal.
SOURCE: 2004 Dodge RAM 1500 HEMI 5.7 Engine Light
take it to autozone they will check why the light is on for free
SOURCE: Need diagram to install serpentine belt on 2004
There should be a diagram under the hood on the fan shroud or radiator support. If not, let me know and I see if I can find one. For the most part, if the pulleys it rides on are grooved, the belt ribs ride on it, it the pulley is smooth, the back side rides on it. From a picture of the alternator I have, from the passenger side coming up, over the alternator, then down and under the belt tensioner (smooth pulley), then up and over A/C compressor, then down and around P/S pump, up and around water pump, down around crankshaft pulley.
SOURCE: replace timing chain on 03 dodge ram 1500 with 5.7 hemi
i have an 02 and i purchased a repair manual from autozone
SOURCE: I have a 2004 dodge ram 1500 with hemi 5.7. The
Hi!!
The O2 sensor for Bank 1 is located below left front of transmission, in exhaust. Check diag. below.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
