One toaster slot only toast one side of the bread
The other side that isn't toasting has an open element. Usually, the good side will burn twice as hot, and may have stressed that element. You might want to replace both in that slot. make sure you check the voltage rating plate. 208 and 240 volt toasters use different elements.
I just posted the procedure to replace elements, in a similar post here.
Toast one side of the bread
This would be an electrical problem, if you can open up the toaster and find the main cord, then try to fix it from there, if you can not open it up, then you may need to replace it
My e-mail address is
[email protected]
SOURCE: one slot only toast one side of the bread slice.
You may need to replace your toaster, but don't worry, just go to the following address:
http://shopping.msn.ca/results/toasters/bcatid1150/forsale?text=category:toasters
Hobart E27 4 slice toaster One ot the slots toast only one side of the bread slice?
