FixYa.com
Tags:
Intel Motherboard
Motherboard Installation Problem - Intel DP35DP (by 3 users)
posted by TonyBuenger on Oct 12, 2007
I just installed the Intel DP35DP with an Intel Core Duo processor, I also added the required DDR2 RAM. I also upgraded the power supply.  When I turn on the computer nothing happens.  The monitor says No Video Detected and the USB ports don't work (i.e., I plug in any USB device like my lighted keyboard and nothing happens).  I also have a new GeForce 7600 PCI-E graphics card.
The first time I turned it on after installation the initial Intel screen asking me whether I wanted to use F2 to configure the system. I couldn't do it because my USB keyboard, USB mouse, etc doesn't work. When I powered off and on again I get absolutely nothing but the blank video screen.
Comment by TonyBuenger, posted on Oct 12, 2007
Unfortunately the DP35DP motherboard doesn't have standard keyboard and mouse connectivity. It's USB or nothing, so I had to go out and buy a USB mouse and keyboard.
I'll try clearing the CMOS and see what happens.  I'm also going to install an internal PC speaker to see what kind of audible I get (if anything). I originally bought this computer as a DAW, so it didn't come with an internal speaker (DAW's usually don't so there's no wayward Windows sounds happening while trying to record music).
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by momochas, posted on May 11, 2008
I have the same problem, with same motherboard DP35DP only that I am using a XFX8600GT with 512MB cache. I installed the mother board with Intel Core 2 Duo E8400, also the video card and no getting any video signal.
Need assistance !
Comment by johnzed, posted on May 02, 2008
Oh, BTW. I am also building a DAW so didn't bother to try to connect a speaker. Turns out there is no such connection except for (apparently) an onboard piezo thingy and the onboard 7.1 audio - that gives me an idea, maybe the post signals are sent out the onboard audio system? Sounds unlikely but I'll try.
Best Solution
posted on Oct 13, 2007
FixYa! (100)
mistyman
Rank:Wiz Wiz
Rating: 82%, 275 votes
Hi, the best solution I see is to log on to the makers website locate the download and support for your board and download the manual [usualy in PDF] and also a copy of your boards drivers.
I had to do exactly this with an Acer board with USB mouse & keboard sockets.
Regards mistyman
Rating Locked! (?) TonyBuenger has rated this solution as FixYa!
Solution #2
posted on Jan 31, 2008
Helpful (85)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
i can install my sound deriver
Was this solution helpful? Show your Appreciation by rating it:
Solution #3
Inappropriate (40)
995225
Rating: 40%, 1 votes
Have you tried clearing the CMOS, and rebooting with a standard keybord and mouse. ? (non usb)
Solution #4
posted on May 13, 2008
Not Rated (0)
momochas
Rating: 0%, 0 votes
Try checking the connector of your power source to the 2x2 pin connector of the DP35DP MOBO. In my case it was missing and was the reason for the blackouts.
Solution #5
Not Rated (0)
johnzed
Rating: 0%, 0 votes
No solution, I'm afraid but I've had what could be a similar problem. Board DOA, apart from the small LED built in, and a flashing power LED (front of case), nothing. No spin ups, no fans (powered from a separate board). Have you yet worked out what caused your problem? I have a new PSU, I've swapped out the video card. My best guess, is something to do with the board arriving in a power-off or standby state that does not recognise my power supply (Tegan 500W).
Solution #6
posted on Jan 29, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
if your motherboard touched the case it did blow!
Solution #7
posted on Nov 06, 2007
Not Rated (0)
almast
Rating: 0%, 0 votes
In my case the chasis was flat causing back of the mother board touch the chasis board. It caused the short circuit and i think blowed my motherboard.
Is there any special power requirement for dp35dp. Other configurations are same as first post
Can you Help with these Motherboards problems?
Intel Motherboard
hallo
i want to get cd mainboard of... Answer This...
Motherboards
change the start up logo on a...
hi i would like to know how... Answer This...
Intel Motherboard
how can i get pass cold
how do i get the passcode to... Answer This...
Motherboards
urgente¡¡¡¡...
como puedo hacer para... Answer This...
Intel Motherboard
Recivers prices
what do you think is the best... Answer This...
Repair Service
Find Motherboard Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
