Microwave Ovens Logo
A
Anonymous Posted on Nov 26, 2013
How to scan for channels on bauhn -actios 40 cm tv
merlyn tumalad
Level 1:
  • Contributor 1 Answer
  • Posted on Feb 09, 2014
merlyn tumalad
Contributor
Level 1:
Answers
Questions
Helped
420
Points
0
Please help me to scan channel bauhn actios
1helpful
Sharp r884. Will there be enough space for safety in my housing unit for it which is 570 MM. Wide, 315 MM high, 580 MM deep.
Dimensions (WxHxD): 52x30.9x48.8 cm - Should fit in your space, however ... this doesn't leave much room for air flow unless there are vents in the back. There must be somewhere for the hot air to go.
Threre sound from the all the channels but there is no picture.
hi just contact ur TV operator its because ur picture tube might have got damaged since repairing it all urself is a risky task i would recommend ur TV to get serviced once if it has been more than 5 years was this useful to u if yes pls rate my solution
with warm regards-bonefirediv
How do i set the clock on my panasonic microwave NN273S
The manual can be downloaded from this webpage:
http://safemanuals.com/314159.php?k=8d9a3f0a84880d830b94d85ddff5a109&ID=205764&q=PANASONIC%20NN-S550WF&cM=-1
1helpful
Cm 1929 error code e41
i there i have a samsung cm1929 microwave and it coming up with the code e41 please help thanks mike
Sanyo EM S667W 1000W 240V Microwave.
Please do not operate the microwave (other than short bursts when testing) until the cooling fan is working again.
Otherwise, the magnetron will be destroyed, and that's expensive.
When the magnetron overheats (since the cooling fan is not working) the magnetron thermostat opens up to kill power and protect the magnetron until it cools back down again.
Chances are you have a bad connection, bad relay, or bad component driving the relay on the control circuit board.
If you will scan (at 300dpi if possible) the schematic, and e-mail it to me, along with clear digital photos of both sides of the board, I can probably help you get this fixed.
Feel free to contact me directly (and please remind me of your full model number).
William E. Miller
[email protected]
http://www.microwavedisplay.com
1helpful
Bought an Intellowave Microwave a couple of years ago and the 'white' paint under the glass plate has come off. I always buy LG products as I have a 106cm TV,had a 68 cm TV but wanted to upgrade for the...
Normally this is due to spills, excess moisture or insufficient ventilation.
The chipped area should be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
1helpful
Nu-tec NTV2131 51cm TV
Press the 'display' button for 5 seconds
Repairing Sansung Microwave version CM 1029
first check voltage to hv transformer if volts probably loose contacts on magnetron ,cap ,diode if still change magnetron
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
