Visioneer One Touch 9450 Flatbed Scanner Logo
Posted on Oct 10, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Problems I have deep black vertical lines on my scanned in documents. All parts have been cleaned!
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 12, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
140
Points
I just called the Xerox customer support number (800-648-0410) and they solved that verticle line problem in 10 seconds. Here's the solution: Clean the white-strip raised section on the top portion of the glass with some isopropyl alcohol on a rag. There is a piece of dirt there that shows up as a line when it runs through the document feeder. If you're just scanning on the glass, you don't see it because it's just a spec of dirt, but through the feeder, the dirt shows up as a solid line throughout the whole document. By cleaning that section off, it takes out the line. Viola! I worked for me. That's the second time I've called Xerox for a problem with my scanner, and I would like to report that their customer support is awesome!
Samuel Konger
Level 2:
  • Expert 106 Answers
  • Posted on Oct 13, 2007
Samuel Konger
Expert
Level 2:
Answers
106
Questions
Helped
55378
Points
127
If the the scanner is based on lLED then probably one of the LED is not working, and if this is florescent tube based then there is somthing wron with the CCD or the Reflector. open it and check it for a spot in the reflector.
Anonymous
Level 3:
An expert that gotĀ 10 achievements.
Genius:
  • Master 2,985 Answers
  • Posted on Oct 12, 2007
Anonymous
Master
Level 3:
Genius:
Answers
2985
Questions
0
Helped
1028423
Points
5636
Assuming the the Glass is cleaned-  and the device is mechanically functional- then the only other thing to go wrong is the CCD- the image capture device- at that stage I suggest there is no repair feasible only replacement of the whole unit.
However a trawl of the Visioneer Web site/customer support may  give a clue.
1helpful
Vertical Black Line
Probably there is nothing wrong with that scanner, just open and clean document feder with alcohol or glass cleaner.
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
2helpful
I am scanning a photo. I have translucent lines running horizontal through the picture before i print it.
Documents scanned/copied from the document feeder pass over a thin glass area where scanning occurs. Clean this area if sent faxes, copies or scans have black or white vertical lines.
  1. Lift the document cover to expose the platen glass.
  2. Wipe the ADF scan area (C) with a clean, soft, lint-free cloth moistened with water.
  3. Then wipe with a clean, soft, dry, lint-free cloth making sure there are no residues left, especially on the platen glass.
  4. Close the document cover and make a copy of a text document to confirm the black line has disappeared.
A thick black vertical line appears whenever i
you have a problem in your scanner assembly, clean or replace it
Black vertical line along left margin when using the adf to scan.
Check both the Fuser Unit and the Cartridge for lines . In any of the rollers are found with a line that means it needs to be replaced.
One sided scanning is fine, but two sided scans have a 1/4 inch black line vertically down the left side. Cleaning does nothing.
When you say one sided scans are OK, are you using the ADF (auto document feeder) or the flatbed? Are you using the ADF for the two sided scan? What parts have you cleaned thus far? A little more info please?
thanks
61helpful
3answers
Vertical black line in scan document not in copies through document feeder
Lift the lid and to the left of the main glass is a smaller glass; that is what scans during the feeding process. Make sure that it is completely clean; even a speck of dust can cause a line to appear. I took a lens wipe and cleaned mine and my line was gone.
5helpful
2answers
Black vertical lines on the sent copies when faxed on Sharp UX 510
Lift the document feeder cover, and clean the scanner glass.
Please rate solution
Black line while scanning and copying
Open up the document feeder and clean the scanner glass
Top Visioneer Office Equipment & Supplies Experts
littlewheel
Grand Canyon Tech
Grand Canyon Tech
Are you a Visioneer Office Equipment and Supply Expert? Answer questions, earn points and help others
