Question about Hoover Floormate H3000 Upright Wet/Dry Vacuum
Hoover floormate 500 making super loud noise when
Hoover floormate 500 making super loud motor noise sounded like the belt. When I opened it up to check the belt I found none. Rusty motor can I spray it with wd 40?
    Problem Solver:
  • 15 Answers
You have a bad motor in the unit. It time for a new machine
Posted on May 26, 2009
Hello my Hoover works well except it is has gotten very, very loud it wasn't this loud before any suggestions?
Not knowing what the loud sound is, try to determine if it's coming from the spinning brushes or the motor. Those are the most likely problems.
Mar 25, 2016 | Hoover H3030 FloorMate SpinScrub 500...
I've had my floormate spin scrub for 3years now and all of a sudden the motor is make a loud squealing sound. What is wrong? Sounds like it's going to die. Is it? Can it be fixed?
take it to an appliance repair shop for a diagnosis and quote for repairs
could be a simple motor problem or could be more costly
any way the quote will show you to repair or replace with a new model
Nov 07, 2015 | Hoover H3044 FloorMate SpinScrub Wide-Path...
Hi, how do I check my hoover floormate deluxe spinscrub's filter and motor?
Hi Mike! To check the filter on the Floormate deluxe, remove the dirty water tank and pull up on tank lid to separate from the base. Check foam filter for debris, if filter has debris, rinse it with water. To prevent internal damage make sure you are using only the Hoover Floormate detergent. If the machine is still noisy and smells bad we recommend taking it in to a Hoover authorized service center. Follow the link to find the nearest service center to you. Hope this helps! Service Center Locator
Oct 20, 2014 | Hoover Vacuums
Samsung vcu366 making loud noise but picks up
what does the really loud noise sound like? Is it a loud, whining sound? if so, the motor may be getting ready to go out. Also check that the belt isn't stuck-though you would smell burning rubber if that were the case.
Mar 08, 2014 | Samsung Vacuums
Hoover H3030-006 240 V Motor making a loud sound and burning smell
If you have little to no suction, that sound is happening because you most likely have a clog some were in the vacuum.
smell is probably your motor over working itself do to the clog.
also double check your belts on your brushes that they are moving with the motor. smell and sound could come from the brushes being jammed which would cause the belt to freeze and heat up and could burn the belt and or your motor.
if it is still running though your not in the red yetm so triple check that the machine is cleared off all clogs and jams in the belts and brushes.
Jul 02, 2011 | Hoover H3030 FloorMate SpinScrub 500...
Brushes won't spin on FloorMate
you need to replace the belt or make sure the brushes are locked into place.
Jun 18, 2009 | Hoover H3030 FloorMate SpinScrub 500...
Loud noise, smell smoke, brushes turn slower than before, stoped using
yes there are replacement parts for your hoover call any athourized hoover dealer and give them your model # usualy the motors are more expensive than the hole machine
May 22, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
HOOVER FLOOR MATE WILL NOT SUCTION WATER
There are no belts. If it makes the noise with the brush assembly removed the motor drive assembly is bad. It ia a complete assembly that can easily be replace by a repairman or ypouself if you are cleaver with tools. Good luck.
Kirk Thompson
San Juan, PR
Oct 17, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Floormate noise
The motor sounds bad. Use the Hoover web site to locate a shop near you for warranty repair. hoover.com
Oct 09, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Motor grind
try checking the belt, that is probably the smell,
might need replacing
May 12, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover Floormate H3000 Upright Wet/Dry Vacuum Logo
1,096 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
