What is dell bar?
SOURCE: how do i restore my dell back to factory settings
If you mean BIOS setting, then enter the BIOS, choose Restore Defaults.
If you mean your windows installation, use the Operating System reinstallation CD from DELL (the green CD, for Windows XP). After operating system installed, use your driver CD (usually the blue CD from DELL). If you don't have the CD, please contact Dell support center to get the CD (charges may apply).
SOURCE: Dell computer does not boot up - I have a Dell
First I would press (I think) F11 for the boot device. In the Dell boot menu, you will have the option of running diagnostics. Try that.
You can see the Dell splash screen on startup and you can see the options letting you choose what to do. So, you can be pretty sure your CPU. motherboard, and video are OK. The next suspect might be the hard drive or the files on the hard drive. But if you don't get a "no boot device" message, it sees the hard drive. I've also experienced a booting problem if the CD goes bad. So--first run the diagnostics. Then open the case and disconnect the cable from the CD and try booting.
I am assuming (perhaps incorrectly) that you have pushed F8 key after computer startup to see if you can start the computer in safe mode.
SOURCE: I would like to restore my Dell 3100C Desk top back to the original factory condition can you help?
Step by step instructions are located on Dell's support page. Follow the link below. You will want to select the instructions for PC restore first, if that does not work you will need to follow the steps for Manual Reinstallation.
http://support.dell.com/support/topics/global.aspx/support/kcs/document?c=us&l=en&s=gen&docid=DSN_347576&isLegacy=true
Hope this helps
Make copies of all things on your PC you want to save, such as photos, documents and other installed programs. Resetting your PC to factory settings will erase all data on the hard drive. It will erase anything that you installed on your computer after you received it.
Restart your computer.
As the computer is turning on, you will see a blue bar that says "Dell.com" across the top of your monitor. At this time, press the Ctrl and F11 keys simultaneously. If you wait too long, you will miss the opportunity to do this and will have to restart your computer again.
Click the "Restore" option when the next screen appears.
Click "Confirm." The PC will begin its resetting process. This process takes approximately 10 minutes.
Click "Finish" when the process is complete. Allow the PC to restart itself. Do not restart it yourself since it needs to run through its boot program.
Click "Yes" to allow the computer to restart. When it does, it will be at original settings, and you will see the "End User License Agreement" screen. Click "Next." The System Restore screen will appear, and the computer will do another restart.
Once it does another restart, click "OK." You have now reset your Dell desktop to factory settings.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
