SOURCE: Xerox WC Pro 35 - Error 14-563
this code means your scanner has failed to setup correctly. this could be a problem that you would need a qualified tech to service the copier. there is nothing that you can do after you power off and power on (popo) the copier. it could be voltage, pwb board, or a binding scanner assembly.
SOURCE: Xerox WC Pro 423 fault code U4-6 & U4-4
Hello sir; The U-4 code all are fuser problem, there haave noway to fix it the only way is replace the fuser unit
SOURCE: Xerox wc pro 420 is showimg E6
your side or front cover is not fitted well or the sensor doesnt actuated well check it out
SOURCE: xerox wc pro 423 u2-3 problem
my Copise Xerox work center pro 423 are showing on display this error (U4-2) how i can clear this error please please tell me any body if knows
SOURCE: service manual for xerox wc pro 416
This is the correct User Guide and System Admin manual even though it's for a 416Si.
System Admin: http://download.support.xerox.com/pub/docs/WCP_416Si/userdocs/any-os/en/wcp416_SAG_en.pdf
User Guide: http://download.support.xerox.com/pub/docs/WCP_416Si/userdocs/any-os/en/wcp416_UG_en.pdf
Hope it helps!
