Computers & Internet Logo
A
Anonymous Posted on Nov 20, 2013
How install NIPrint 4.0 on 64 bits - Network Instruments NIPrint 4.0 (NIPRINT1) for PC
PC won;t boot after memory upgrade
your comp can only handle so much ram,you also need to use the same ram,check how much ram it recognizes with only two,then 3,then 4,64 bit comps only recognize 4 gb,32 bit recognizes any gb ram.
3answers
Can you run office 32 bit on a windows 64 bit operating system?
You have 32-bit Office installation package (CD/DVD/file) and 64-bit Windows operating system. Is it correct?
General answer is YES, I can install a 32-bit application on 64-bit OS. I have exactly same situation in my laptop. Both 32-bit LibreOffice and 32-bit MS Office are installed on W7 & W8 laptops and work well.
But NO vice versa. The 32-bit system does not allow to install 64-bit application. The 32b system does not support 64b instruction set required for 64b applications.
My experience is confirmed by many other users:
Office 32 bit to Windows 7 64 bit
I had a 32-bit webtricity 2 and other programs that are 32-bit, I have a computer with Windows 7 64-bit and having trouble installing these programs because during compatible with the 64-bit OS is there...
64 bit OS can run 32 bit software but if the software provider has a version for 64 bit it might require you to download this version ad prevent you from installing the 32 bit version.
Kind regards
2helpful
The issue is many Windows 7 installs are 64 bit, and your software does not work on 64 bit installs. Your drivers lists as 32 bit install even. As this is going to be an issue for many people, is there any...
If you have tried installing the printer driver for 32-bit on your computer, you might want to uninstall it first before installing the Lexmark X6650 driver for 64-bit. Go to Start menu -> Programs -> Lexmark X6600 Series -> Tools -> Uninstall. Reboot pc when prompted.
You can download the Lexmark X6650 driver for Windows 64-bit from the Lexmark website. Go to this link: Lexmark X6650 Driver for 64-bit. This driver applies to Windows 7 (64-bit), Windows Vista (64-bit), Windows XP Professional (64-bit).
2helpful
2answers
Can i installed 32 bit applications on 64 bit processor?
The answer to your question above is Yes, you can install 32-bit applications on a 64-bit desktop/laptop. Please note 3 things:
1. The 64-bit environment will be determined by both the CPU and OS being 64-bit capable. If one of the them is not, then the system will not perform at the 64-bit level.
2. 32-bit applications can be installed on a 64-bit OS and they will function properly - but only at a 32-bit level. They will not take advantage of the 64-bit environment until the application is certified for 64-bit.
3. 64-bit applications cannot be installed on a 32-bit environment - they won't run at all.
1helpful
2answers
Can i convert a 32 bit to a 64 bit
You can use the Upgrade option during Windows 7 installation, which preserves your files, settings, and programs, only if you're currently running a 32-bit version of Windows Vista and you want to upgrade to the 32-bit version of Windows 7. Similarly, if you are running a 64-bit version of Windows Vista, you can only perform an upgrade to a 64-bit version of Windows 7. For more information, go to Upgrading to Windows 7: frequently asked questions on the Windows website.
If you want to move from a 32-bit version of Windows to a 64-bit version of Windows 7 or vice versa, you'll need to back up your files and choose the Custom option during Windows 7 installation. Then, you'll need to restore your files and reinstall your programs. For more information about performing a custom installation, see Installing and reinstalling Windows 7‍.
gl_ico.png Notes
  • To install a 64-bit version of Windows 7 on a computer running a 32-bit version of Windows, you'll need to start, or boot, your computer using a 64-bit Windows 7 installation disc or files.
  • If you start your computer using a 64-bit Windows 7 installation disc or files, but your computer isn't capable of running a 64-bit version of Windows, you'll see a Windows Boot Manager error. You'll need to use a 32-bit Windows 7 installation disc or files instead.
  • Windows Easy Transfer can't transfer files from a 64-bit version of Windows to a 32-bit version of Windows. If you're running a 64-bit version of Windows Vista but you plan to install a 32-bit version of Windows 7, you can move your files to an external location manually or use Backup and Restore in Windows Vista. For more information, go to Back up your files and
1helpful
2answers
Can i install a 64 bit of 32 bit Computer?
Yes you can, unfortunately you can not upgrade from 32bit to 64bit, you would need to do a fresh installation. Also your processor and motherboard need to support 64-bit architecture. If you start the installation for the 64bit if the architecture isnt supported it would notify you that the installation can not be completed with an error message.
Enjoy your copy of Windows 7 64-bit if it works.
2helpful
3answers
I cant install autocad 2009 in windows vista 64 bit operating system.
I cant install Autocad 2009 on Acer Apire 5715z, when i try to install the operating system is not supporting
regards,
Johnson Idukkula [email protected]
Adobe Photo Deluxe 2.0 will not work with Vista
yes
if your machine is 64-bit Vista, then you need to install Windows XP-64bit.
you can install Windows 32-bit on a 64-bit machine, it will work. just not as good. However, you can't install 64-bit OS on a 32-bit machine.
if the machine is 32-bit then you can install any type of OS you want, you can even install them as dual boot.
Top Network Instruments Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Network Instruments Computer and Internet Expert? Answer questions, earn points and help others
