K
Kathy Sparacio Posted on Nov 19, 2013
New remote for player
I have a 3 Disc Dual cassette player Model MS9825. Is there anywhere I can get a new remote? Thanks
5 Related Answers
Anonymous
  • 625 Answers
  • Posted on Dec 31, 2007
SOURCE: RCA cassette recorder/player keeps shutting off. argggg
fast forward, reverse the cassette and fast forward again. if the tape is too tight the current sensor will always trip out the motor.
Bruce Showalter
  • 133 Answers
  • Posted on Mar 15, 2008
SOURCE: cassette player problem
Sounds like the take-up reel isn't turning. Often the linkage for the take-up reel is used for both Play and Fast Forward. So test the Fast Forward.
I would look for a broken belt or slipping drive wheel. The fact that the tapes are unraveling tells me that the capstan is pulling the tape out of the feed reel.
Anonymous
  • 15 Answers
  • Posted on Aug 01, 2008
SOURCE: lost power adapters
I have a power adapter for the Dual 7 for sale for $29.99 including shipping to lower 48. any interest, email me at [email protected]. warm regards,
Grubhead
Grubhead
  • 5755 Answers
  • Posted on Jan 21, 2009
SOURCE: Toshiba cassette deck
Try E-Bay!
Anonymous
  • 167 Answers
  • Posted on Mar 09, 2009
SOURCE: Toshiba Remote
you can buy a universal remote if the cost of a replacement is too high. hope this helps, good luck.
1helpful
Home Audio system MS9825 The remote became corroded and we ordered a new reconditioned one which still doesn't work. Can you help or can we order a new remote from you?
You bought a "new" reconditioned remote and it doesn't work?
You should send it back for exchange or refund.
I haven't encountered reconditioned remotes before. I doubt there is much profit in reconditioning remote controls when new dedicated replacements are available at such reasonable prices. Often new original remotes aren't expensive if they are available.
I was attempting to install a new stereo in my 2000 taurus. it requires to an adapter to put the new stereo in. i got the new adapter and stereo in *kinda* but decided i didnt really know what i was...
check your fuses first. You may have blown one.
Visual Inspection Chart Mechanical Electrical
  • Integrated control panel (ICP) physically damaged, misaligned, any control(s) inoperative
  • Digital audio compact disc player physically damaged, misaligned, any control(s) inoperative
  • Antenna or antenna cable physically damaged, misaligned connection(s)
  • Radio speakers, mounting/speaker cones physically damaged, misaligned
  • Radio ignition interference capacitors, radio frequency interference suppression bond misaligned (also check for cleanliness and metal-to-metal contact)
  • Battery junction box (BJB) fuses F127 (5A), F117 (20A), F127 (5A).
  • Central junction box (CJB) fuse F227 (10A) F211 (15A), F216 (15A), F226 (10A) (wagon only)
  1. If the fault is not visually evident, proceed to diagnose the integrated control panel (ICP) by entering the ICP Self-Diagnostic Mode.
NOTE: To enter the ICP Self-Diagnostic Mode, the ICP must be ON and in radio tuner mode (AM/FM).
  1. Enter the diagnostic mode by pressing and holding preset buttons 3 and 6 simultaneously. This will suspend all radio functions, and display SP.
  1. Preset Button 1 = Audio internal/external SELF TEST. The display will flash SELF while gathering the diagnostic trouble codes (DTCs), then stop flashing when complete. Press the TUNE UP button to display the DTCs if any exist. Record codes and refer to the following table:
ICP SELF-TEST CODES Code Description 0 No diagnostic trouble codes logged 1 No response from rear chassis unit (RCU) 2 No response from cassette player 3 - 4 No response from compact disc player 5 - 6 - 7 No response from remote climate control 8 - 9 Read Only Memory Verification failed
  1. Preset Button 2 = Displays the feature strap for code identification, refer to the following table.
Code Description 01 Base-Electronic Search Radio (ESR) with Manual Climate Control (MCC) 07 Electronic Search Radio with Cassette (ESC) with MCC 17 ESC with Electronic Automatic Temperature Control (EATC) 97 Not programmed default of ESC with EATC
  1. Preset Button 3 = ICP and RCU identification. This test identifies the software level of the ICP and RCU. The ICP is tested first, followed by the RCU. The display will have two sequences of three codes each. The first sequence is for the ICP, the second sequence is for the RCU. For code identification, refer to the following table:
Item Part Number Description 1 - Product variant code 2 - Tape model 3 - CDR
SOFTWARE IDENTIFICATION CODES Product Type Code Description Product Variant Code Description 21 ICP 07
08
09
10
11
12 EATC with AM/FM, cassette player and CD changer
EATC with AM/FM and cassette player
Manual A/C with AM/FM and cassette player
EATC with AM/FM cassette player and CD changer 31 RCU 01
02
03 Analog
Digital
Midline 71 Remote climate control 01 LH drive 52 Compact disc/disc jockey 01
02
03
04 Sony® 10 disc
Sony® 6 disc
Clarion® 6 disc
FMS 6 disc
I have a PYEvideo dvd recorder with video cassette recorder,PY90VG.i need remote control # NB654UD.remote control quit working
Provided you know the part/model number of the original remote, and you're prepared to spend the extra few dollars to replace the original remote with an identical new one, assuming it is still available, then go ahead and order it. Otherwise try a universal remote which is cheaper.
Not all functions can be guaranteed with a universal remote but most of them should work. Universals are cheap enough to buy just about anywhere. Only consider this option if the original remote control is not possible to buy or no longer available.
I bought one on ebay and it is in excelent shape however the cd player doesn't recognizes disc. I opened the unit and it seems to be working ok but says "no disc" any tips? Henry
All you can do is clean the lens and if that does not do it at this point Russ at New Jersey Factory Service has said they don't support that model anymore.
Cd player quit working
TRY LASER CLEANING DISC. FAILING THAT IT COULD BE THE LASER HAS DIED OR SERVO PROBLEMS.
New remote
I need to find a remote for my Durabrand DUR7 Ok
Thanks
Top Emerson Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
