TOC stands for Table of Contents. On a MiniDisc recorder or CD recorder, a Table Of Contents MUST be written before a disc is usable. On A player, a TOC must be read before the unit knows where to find the songs. Sounds like the laser is NOT reading the TOC, so you will hear nothing until that is corrected (clean lens or replace unit). Try a storebought CD, as perhaps is doesn't like your own burned CD's and most units built before 2000 will not read your own CD's that you make.
SOURCE: CD's won't play
I know that Panasonic provides chips, optics (laser),etc. to Emerson. I am familiar with the problem you've experienced because I've had a Panasonic CD Player. If the disc doesn't spin (as you said), the problem must be that your shelf system probably has an optical problem (laser problem/pickup problem) and will need to be serviced.
