Washer stopped working in middle of cycle no power
SOURCE: samsung j845 oe error
What you need to be looking at is the water lever sensor. Take the top off by removing 2 screws in the back (Top right and top left). Slide the top off. Now you want to be standing in the front. The front right side is the sensor. Make sure the hose is properly connected underneath. If you have a meter, take a resistance measurement across the two end pins. Should read about 20 ohms or so.
SOURCE: My Samsung WF218ANW/XAA front load washer will not
lefever352, I am currently trying to solve this same issue on the identical model. I removed , cleaned, and re-assembled all the water tubes and the entire pump assembly. The pump works but for some reason it is not priming into the drain tube. The pump assembly appears to have a diaphram over the outlet opening and it it looks like this might be the problem. I am still hunting the solution, BUT so far the above actions have to resolve our issue. I hope perhaps Fixya can help.
