VinoTemp VT12TEDS Wine Cooler Logo
Dorothy Brundage Bell Posted on Nov 17, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Not running red light on Control board is flashing.Nothing running ,Just light flashing.
Brian Coughlan
Level 2:
Champion:
  • Expert 280 Answers
  • Posted on Nov 22, 2013
Brian Coughlan
Expert
Level 2:
Champion:
Answers
280
Questions
0
Helped
87122
Points
430
If it is the running light then a component has failed. Call for service.
I have a sebo x4 , when I switch it on the red lights flick on and off and nothing happenes
The red lights should flash very quickly upon vacuum start-up (normal). If the motor is not turning on there is likely a problem with the motor or power supply board. The lights flashing does indicate that you are getting power to the PC control board. If your vacuum is under warranty, this would likely be covered. I have included a link to the parts list for your reference. http://sebo.us/pdfs/website_schematicsPDFs/AUTOMATIC%20X%20Schematics.pdf
2answers
Keypad doesn work
the red light should only blink when it is running. does the incline work? if nothing works most likely a console issue
Lennox ac stops working after normal shutoff untill i shut off power to air handler turn power back on ac runs till nornal temp reached shuts off will not come back on untill i kill power to air handler...
The 13HPX is a Heat Pump. It has a control board in the outside unit that will lock out after a few trips from one of the controls, such as a low or high pressure switch tripping. Turning the power off is making this board reset. Take the door off next time. to the outside unit and look at the lights on the control board. There should a sticker on the inside the door that you have to remove that describes why the unit is hard locking out according to the light configuration.
Cycle won't start/start light flashing red
Probably a bad wax motor in the door switch or a bad control board.
Yeah you should call someoneif you're not a learned handyman.
2answers
How to fix a treadmill
see the video attached. lube the rollers bearing front +back.
However you must test the terminal motor voltage with multimeter, if there ARE THE MOTOR IS faulty. see my personal TIPS.
2) test the measure output voltage from control board for input voltage terminal motor if there ARE NOT, the board is faulty.
God bless you
Indesit Washing machine WIL88 red light flashing
Seems that the main board or the processor is hanging up and does not take up the full process control. You need to remove the panel and check for moisture on the board, check for loose connectors. If this seems fine the fault seems related to the board and can be confirmed with a board swap before one can be ordered. Check the door switch and wiring to the main board.
I HAVE A 45000 BTU GOODMAN FURNACE RED LIGHT
There may not be a call for heat being registered by the control board. Take the R and W terminals on the control board and put a jumper between the two. If the heater starts, you have either a broken thermostat wire or a bad thermostat or connection.
AquaLink RS 4 top lights flashing red bottom lights flash yellow
I don't have the "one-touch", but on the "all-button" there's a hole on the left side of the unit. A paperclip inserted in this hole will reset the unit. I had a problem with the display on mine and this fixed it.
Top VinoTemp Refrigerators Experts
ADMIN Andrew
ADMIN Andrew
Larry Ng
Larry Ng
Are you a VinoTemp Refrigerator Expert? Answer questions, earn points and help others
