I have a Price Pfister Catalina R89-7EBK shower. The head leaks water a couple of times a day. We do not use the shower. The cartridge appears to be fine. I called a plumber who wanted to replace the cartridge but was not sure if the problem would be fixed. My dad thought there may be a pressure release using the shower head.
SOURCE: single handle tub faucet will not divert to shower
the diverter on the tub spout is bad you need to replace the tub spout or the pull up diverter if its a separate piece if you have the owners manual with a parts diagram you can order it on line from the manufacturer or a plumbing supply store. you will need to unscrew the tub spoup from the wall to do this use a broom handle or something similar inserted inside the spout and turn it to the left to remove it from the wall
does it leak from the showerhead the extention pipe or, the handle (knob) assembly?
