I need to reset BIOS Password on Toshiba L745D. I am unable to find the Jumper (B500?) on motherboard, so want to replace CMOS battery, however, the battery is locked with a plastic cover which is soldered to motherboard. Any help is greatly appreciated.
You may be able to reset the bios by shorting out the battery leads for 30 seconds. This may however completely drain or damage the button battery.
The only other way to fix this would be to unsolder the battery and solder a new one back in I've done it before on a dell laptop.
Update: I was able to pop out the battery by twisting the plastic a little bit.
The password is STILL THERE! Battery was out for 24 hrs, but no affect on BIOS Password. Please help!!
Even with the battery out you need short the battery connection. You can do this by placing the battery in upside-down. If that doesn't work you may need to flash the bios.
Otherwise you can try these suggestions.http://www.fixya.com/support/t7705112-re...
SOURCE: I changed RAM settings in BIOS, now I can't boot - need to clean CMOS
Pg. 1-15 in your manual. Do both. Clear the cmos by switching jumper to pins 2&3. Make sure the power cord is unpluged. Use a flat head screw driver to help you lift out the battery. Wait a few seconds. Pop the battery back into it's holder & reset the cmos battery back to pins 1&2. Plug the power cord back in. Boot the Pc & press the delete key to enter the bios. If the Pc is beeping remove the memory & reseat. Try another boot up.
Award BIOS Beep Codes: Repeating (endless loop). Check for improperly seated or missing memory. If beep still continue, only place 1 dimm in slot A closest to CPU. Do not forget to unplug power cord before messing with the memory or switch the PSU to off. Wait for the green light on the board to go off.
SOURCE: CMOS resetting Clearing
I had the same problem.
I fashioned a small piece of wire, and with each end, shorted the two sides of the battery together, - thereby removing the BIOS settings through a loss of power.
Do this only briefly though - you don't want to drain / destroy the battery altogether, as this will hold your future bios settings in the cmos chip.
Good luck,
Erik.
SOURCE: elite K7SEM Cmos battery replacement problem
Try to verify the real battery voltage and polarity (use multimeter) or cleaning the socket contacts.
SOURCE: CMOS battery getting hot.. bad jumper setting... help!!
you can downlaod the manual which shows the jumper settings, plus diagnostic software and drivers for your board from the makers website at the address listed below.
http://support.asus.com/download/download_item.aspx?product=1&model=K8S-MX&SLanguage=en-us
Please rate this answer and good luck.
SOURCE: Where is cmos reset jumper? Is it near battery,
Try
http://support.acer.com/acerpanam/manuals/acer/0000/servicemanuals/S.G_Aspire_M5640_M3640M1640_BOOK_VerC.pdf
page 77
label CLR CMOS 3 pin type 1-2 clear 2-3 normal
Battery Cover
Thanks for the images they really help.
