Ovens Logo
Sue Flint Posted on Nov 15, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Charcoal grill model no BG7-05
The pilot light will light but as soon as the dial is released the light goes out
mburke3
Level 2:
Sergeant:
  • Expert 459 Answers
  • Posted on Nov 20, 2013
mburke3
Expert
Level 2:
Sergeant:
Answers
459
Questions
5
Helped
91550
Points
629
Turn gas off and clean out all lines going from gas valve to pilot with compressed air. put the lines back together (be sure they seal)
try the pilot again
1 Related Answer
Anonymous
  • 19 Answers
  • Posted on Jan 14, 2011
SOURCE: Interthrem mac 1165
You need a new thermocoupler
Griller not staying alight after lighting
The Thermocouple safety device needs replacing. The thermocouple usually has a pilot light deflector over it. Make sure it hasn't moved or fallen off, or rotted out.
Please always include full 'make model (what it is)' as first 3 words in every question.
https://www.google.com/search?q=TEB21Y
Feb 15, 2024 • Ovens
2answers
How to light grill
switch the dial to the indicator which shows the top grill,usually this is a black line with a squiggle under it.
Sep 15, 2016 • Ovens
MY SUBURBAN OVEN PILOT LITES, BUT WHEN i RELEASE KNOB PILOT GOES OUT AND OVEN WONT LITE. i REPLACED SAFETY VALVE BUT STILL SAME PROBLEM.
the polit light lights but when you let the nob go for the oven burner to come on the polit light goes out
Sep 22, 2011 • Ovens
Oven no gas
pilote tube could be blocked or pilot orifice set too small. check that the gas pressure is ok
1helpful
Morning I need help please regarding my gas oven (Beko SCG7530). The problem is when i turn the gas knob on,(push and hold for say 10 secs)the oven works fine,but as soon as the knob is released the gas...
Sugar,
Sometimes it takes a minute or longer for the thermocouple to get hot enough to send the correct voltage to the main part of the gas valve to get it open & the burners to light. If after a few attempts of turning the pilot knob to off, waiting a couple of minutes and then going thru the lighting process, your problem is the thermocouple. Most repair companies will NOT install YOUR parts because of the liability & warranty issue. The best bet is to call a repair co & explain what the problem is & tell them to bring a thermocouple with them. Sears or calling your local BBB is your best course.
Jul 09, 2009 • Ovens
7helpful
No manual
The light bulb is the oven light.
The snowflake with 3 raindrops is Defrost Mode (fan runs with no heat to reduce defrost time)
The 2 lines up top & down bottom is Traditional Cooking (heat from top & bottom elements)
The big circle with a fan is the Fan forced Oven
The small line at top only is the Grill Mode
The larger line at top only is the Double Grill Mode
The line up top with the fan underneath is Double Grill with Fan mode
The line on the bottom with fan on top uses the lower element with the fan for delicate dishes
The manual can be found on the Baumatic website - www.baumatic.com.au - select your product which takes you into another page & you will see on the left hand side a link to "View User Manual"
2answers
The pilot light for the oven went out.
Relighting Your Furnace's Pilot Light
furnace1.jpg - Turn off the gas at the main valve at your utility box - Wait five to ten minutes for gas fumes to waft away - Get a long match—yes, a fireplace match, not a standard match - Set the gas valve on your furnace to "pilot" - Press the red button as you hold the match to the pilot valve - Keep pressing the red button for 30-60 seconds so the pilot can heat the thermocouple. Release the button and see if the pilot remains lit - If pilot goes out, wait five to ten minutes and repeat the process - Once the pilot stays lit, turn the main gas valve back on - If the pilot light continues to go out, call a technician, who may need to adjust or replace your thermocouple or adjust your pilot
Interthrem mac 1165
Jan 23, 2008 • Ovens
Top Fagor Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Fagor Oven Expert? Answer questions, earn points and help others
