Mine just done the same thing all you need to do is hold down the off/lock button for at least 15-20 seconds then the screen should turn black which means you can turn t back on again and It should work.
You can hold the home button and the power button simultaneously until the iPad powers off and resets itself. Once the Apple logo appears, release the buttons. Hope that helps!
Unplug power supply and remove main battery, press and hold power for 2 minutes to remove residual voltage. Now re-install battery and plug the power supply/charger and activate your laptop.
It doesn't matter if your computer cannot recognize the Pearl before you run the software, it will find it anyway. Follow all the troubleshooting steps at the bottom of the popup window.
hi friends, there may be dust and improper shutdown of your laptop if you know how to remove the back side panel , remove it and clean the ram and ram slot and put the ram into the ram slot, please try it will work, if prob comes again please inform to fixya.com
