Oven does not work after self clean
Sorry to hear you`ve had an ongoing issue like this. Can you tell me what the model number is of your oven ? Can you also maybe touch on what step`s have been taken in the past when this occur`s ?
Depending on the model and vintage of your oven, it likely has tripped the hi-limit thermostat. The good new`s is it is typically easy to reset as it is a manual reset type hi-limit as opposed to one time non-reset. Also this hi-limit is either located on side, back, or behind the grill between the oven door and control panel/fascia. Let`s hope for the later.
**Always shut off power to the unit before performing any service/repairs**
If it is indeed just a tripped hi-limit as I suspect, ( it is common after self clean cycles on many ranges/ovens, not just Thermador ) I have a few tip`s and suggestion`s after you`re up and running, but we`ll cross that bridge when we get there.
I`ll watch for your reply. Good luck.
macmarkus :)
