Craftsman 26 Hp 54" Deck Yard Tractor Logo
g
gary anderson Posted on Nov 07, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Small farm tractor starts won't stay running
Starts wom't stay running
mickey813
Level 3:
  • Master 472 Answers
  • Posted on Nov 15, 2013
mickey813
Master
Level 3:
Answers
472
Questions
0
Helped
215324
Points
1078
Sounds like the carb has some bad gas in it or it may have some trash in it plugging up the jets
1helpful
Have a yardman 19hp riding mower briggs and stratton engine replaced cables starter solenoid.Engine starts when u put gas in carb but won't stay running can u help?
Lisa, Make sure fuel supply shut off is on and fresh fuel in tank. Could be clogged fuel filter, fuel pump issue if equipped or a fuel shut off solenoid,dirty carburetor, etc. Check the attached links,instruction and guides on trouble shooting no fuel to engine. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Repair Small Engine Problems Briggs Stratton FAQ
Diagnose small engine problems with the FAST approach Farm Forum
Small Engine Repair Checking Vacuum Fuel Pump Fuel System on Kohler Twin...
DIY Carburetor Replacement On Lawn Tractor With Briggs Stratton Engine
May 31, 2016 • Garden
Farm pro raider(Homier)
Only thing left is compression. Stuck valves will affect compression as well as worn rings.
Farm tractor revving up and down then will shutdown
The tractor I have operated had a sediment bowl/ water trap.Try cleaning that out.
Jan 02, 2014 • Garden
Will not start
CHECK THE FUEL FILTER FIRST. BY PASS IT WITH A DOUBLE BARBED FITTING WITH HOSE CLAMPS. IF STILL WON'T STAY RUNNING THEN CHECK THE FUEL BOWL FOR DIRT,SAND, DEBRIS .ITS LOCATED ON THE BOTTOM OF THE CARBURETOR.MAKE SURE YOUR FUEL DOESN' SMELL LIKE TURPENTINE OR HAS WATER OR ORANGE LIQUID IN THE BOTTOM OF THE FUEL TANK-THIS IS WATER. TRY REMOVING THE FUEL TANK CAP AND STARTING WITHOUT IT FIRST-IF IT STAYS RUNNING THEN THE SMALL OPENING IN THE CAP IS CLOGGED WITH DIRT.
Oct 13, 2012 • Garden
Sears intek 20 hp, fresh gas, filters air and gas, oil, and plug still won't start where should small valve and screw adjustment be set to, may be the problem don't know. won't stay running...
If you have not been putting gas treatment in your gas to treat the ethenol they have been putting into the gas its a good chance its the needle valve in the carborator. If you live in a state that does not add ethenol to the gas disregard this advise.
Jul 10, 2011 • Garden
1helpful
I have a 2003 trailblazer and it makes an aweful WOM WOM sound from the tire. If it is the wheel bearing woud it make the ABS light stay on?
The abs is intergrated into the wheel bearing. It is quite possible a bad wheel bearing will cause the abs light to stay on.
2helpful
When idling or driving van makes a wom wom wom noise coming from the engine compartment a guy i work with has a town and country and it makes the same noise
The wom wom wom sound you are describing could be coming from a sporadic intake of air. Check for air leaks in the fuel filter hose as they have a tendency to dry rot. I may be wrong, it could also be coming from a variety of ailments but this is the simplest place to start. Also check for vacuum leaks.
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
