Engine model 42A777 type 1270-01
Lisa, Make sure fuel supply shut off is on and fresh fuel in tank. Could be clogged fuel filter, fuel pump issue if equipped or a fuel shut off solenoid,dirty carburetor, etc. Check the attached links,instruction and guides on trouble shooting no fuel to engine. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Repair Small Engine Problems Briggs Stratton FAQ
Diagnose small engine problems with the FAST approach Farm Forum
Small Engine Repair Checking Vacuum Fuel Pump Fuel System on Kohler Twin...
DIY Carburetor Replacement On Lawn Tractor With Briggs Stratton Engine
Thank U for all your help and support we got this mower running unfortunately U have to jump it off thesolenoid and to stop it you have to choke it out so now we're trying to figure out why it won't start and shut off right so if you have any ideas we're open for suggestions. Thanks Bunches
Lisa, check for in line fuse in the ignition harness, it may be blown, solenoid could be bad, starter switch, plug, wires could be faulty,corroded,damaged. Google search (lawn tractor not starting from ignition switch) for more detailed info. and test you can try.
