Garden Logo
A
Anonymous Posted on Nov 06, 2013
What size file to sharpen chain
Les Page
Level 2:
Champion:
New Friend:
  • Expert 256 Answers
  • Posted on Aug 10, 2014
Les Page
Expert
Level 2:
Champion:
New Friend:
Answers
256
Questions
Helped
72054
Points
275
The size of your chain dictates the file size. If I know your chain size I could help you
How to sharpen chain saw chain
Hi
You need to purchase the correct diameter file for the size of chain you have fitted on your saw. Suggest also that you buy a Stilh file holder (this is a frame which holds the file, and acts as a guide to give you correct filing angle and depth, just a few dollars).
Do not file too much off each time, I give each tooth two files strokes only. You have to keep the saw sharp all the time, I sharpen every two tank fills of fuel.
Suggest you Google the subject, Oregon chain is a good make and will have details of how to sharpen
Good luck
Jacko from down under
Chain file sharpening size
For the normal size chain you use a 5.2mm round file. Smaller chains for top handles take a 4mm round file.
Size file sharpen poulan 18
Take your saw to a shop that repairs chainsaws. They will be able to get you the right file for the size of chain on your saw.
How to sharpen chain on poulan pro 20 inch chainsaw
It can be done with a file of the right size for the chain. I take my chain off the saw and to a chain saw shop for a professional job.
1helpful
What is the file size (to sharpen chain) for a Poulan Pro 295 46cc?
I am pretty sure this machine ran a .325 pitch chain, so the file size is 3/16, if it is running 3/8 low profile chain ( 91 ) it will be a 5/32 file, the pitch should be marked on the bar .
2answers
Engine starts, runs, chain goes around, but cuts very weak, leaving black marks on the wood from rubbing but not cutting
You have a dull chain. Check out the video below to learn how to hand sharpen the chain:
Thanks for choosing FixYa,
Kelly
We have a model 137 chain saw. I need to know what size file to sharpen the chain and the correct angles for this model.
all saw blades are sharpened to the same angle. 37° the file size you are going ot want is 1/4-3/16in.
2helpful
2answers
1helpful
Looking for sharping stone from efco fl64 /8 chain
There are multiple chain sizes 1/8", 3/16", 1/4", 5/32", 7/32" and 3/8" chains so the /8 chain number has me guessing. After the qurestions below, here is my best guess.
Also is this for a chain grinder?" or
Are you looking of a hand held type stone?
Aluminum Oxide Chainsaw Sharpening Grinding Stone
or Ceramic stone?
I will assume that your looking for aluminum oxide stones at this time.
http://www.oregonchain.com/homeowner/products/accessories/replacement_stones.htm
This is wide selection of sharpening stones.
You can also use hand held chain sharpening files of the same size that have shapening angles marked on the file set fixture.
Hopefully you have a sharpening guide that will keep your angles correct while shapening.
A safety note: Improperly sharpened chainsaw blades can be very dangerous to the user.
Thanks for using FixYa.
Kelly
4helpful
What size file do i use for a Ryobi chainsaw model PCN4545 to sharpen the chain
The standard chain file should fit it. It is about 3/16 dia. I found the dremel to work 10 times better, they have a little stone bit just for chains. Eventually, you have to take it in for sharpening, it will set all the teeth the same.
Top Garden Experts
Jay Finke
Jay Finke
john h
