I suspect that the battery is dead and when you turned on the lights there is insufficient current from the alternator to run everything so the ignition shut down. Have a load test done on the battery and check for bad cells as a battery sitting unused for 2 years will be sulphated up on the plates.. Fit new battery and reset the CPU with a code reader.
Testimonial: "Thanks you agreed with my answer to my boyfriend~will check battery~got battery 2011 w/ 8 yr warranty,so will check that too"
SOURCE: 1998 Ford Explorer
had same problem when my rear wiper motor went out. I had to locate all the rear wiper motor fuses and take them out to stop it. Am now waiting to replace my wiper motor.
SOURCE: my truck turns on but does not move forward
my ford truck reverse and turns on but it wont drive?
SOURCE: my 2005 chvey 2500hd diesel truck will not start,
on the back of the engine close to the firewall by the glow plug controller is a high pressure oil switch. if this switch goes out diesel fuel will not reach the injector pump.try pulling the molex and jumping it out with a wire. if it starts. replace the switch. it takes an extra deep socket designed for that switch that can be purchased at any auto supply. good luck!
