Did you wait a few minutes to check oil once it drained back to oil pan? The alternator can quit,but the car will run on the battery for a short time until it is dead..this is usually marked by a sudden sluggishness,low voltage indicated on batt gage,then sudden shut down..Try jumping the battery,it will start,then pull off the pos cable,it it dies immediately,have alternator tested/replaced...good luck
Could have overheated because low on oil, the engine may not start until the computer is reset, a safty feature which keeps the engine from damage in such cases., Take it to a mechanic to reset the computer if you think the oil being low was the main issue.
SOURCE: 85 xj6 4.2lt. fuel injected, (Problem will not
Does it even try. (cough and sput) Will it start if you spray carb cleaner in it?
SOURCE: Buick Regal dying
You have a problem in the fuel pump relay circuit for sure then. I'm betting the relay, but it could be that dropping resistor.
SOURCE: 1987 chevy s10 2.5l tbi will not start. changed
That eliminates the crankshaft and camshaft position sensors. Have you checked the fuel injector itself for an open winding or stuck valve plunger? There should not be a steady 12 volts to the injector--if good injector, it would be spraying fuel steadily into the throttle body. But at least the engine should try to run if poorly. Take the injector out, dry it off with air, and intermittently apply 12 volts to one terminal while grounding the other. You should hear a click from inside every time you touch 12 volts. If not, replace it. If it does, it may be plugged with debris. Try blowing through it in reverse with compressed air.
SOURCE: fuel in oil on 2002 chevy 2500hd duramax
THE DURAMAX ENGINE INJECTORS GO BAD AND SPRAY TO MUCH DIESEL AND IT FILLS THE CRANK CASE UP 200 THOUSAND MILE WARRANTY COMMON PROBLEM DON'T DRIVE IT ANY MORE IF U HAVE BAD INJECTORS.
SOURCE: 2003 Tahoe, 5.3 liter vortec flex fuel. Engine
this is a comon problem on chevy 00-06 models a computer ground ,it seems ok at sight but inside it's just holding a few wires ,get under the car on the driver side passenger there you should find a two ground wire goin to the block a big, and a small ,the small one gets coroded try to fix it and let me know how it goes ok.
