Compaq FP 7317 17" LCD Monitor Logo
Posted on Oct 01, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Compaq FP 7317 LCD monitor flickering
I am stuck in Malawi in Africa with no access to any competent technical assistance so would greatly appreciate advice. My Compaq FP 7317 LCD monitor is 18 months-2 years old and has just started flickering very slightly. There is no distortion and the colours are fine but I would like to know whether this means the screen is on its way out or whether there is a simple fix to this problem. I'm hoping it's the latter because we don't have access to affordable hardware replacements out here! Please help!
Anonymous
Level 1:
  • Contributor 38 Answers
  • Posted on Oct 04, 2007
Anonymous
Contributor
Level 1:
Answers
38
Questions
Helped
32572
Points
53
Right click on your desktop, go to properties. Go to settings tab. Go to advanced. Select Monitor Tab. Under Monitor settings select a higher screen refresh rate. It should fix your problem :-)
mukhtar21 shaikh
Level 3:
President:
  • Compaq Master 2,022 Answers
  • Posted on Oct 03, 2007
mukhtar21 shaikh
Compaq Master
Level 3:
President:
Answers
2022
Questions
Helped
669350
Points
5817
Try with change the resolution .it will littl ebit help out . othewise show it service personnel. bye
Hi,.. I was given a compaq FP 7317 with the tower, key board,...monitor keeps saying "going to sleep" when I finally got it all pluged in. HELP. HOW TO GET OUT OF GOING TO SLEEP?
To disable sleep mode in vista follow the steps
Go to start and type in the search box Power Options hit the enter button
On the Left side there is a panel Click Change when the computer sleeps
Click the drop-down box which says Put the computer to sleep and select Never
Click Save changes
Monitor displaying check video cable
Please check the connectivity of the cable that runs from the Monitor to the Box.
It is usually with Blue color connectors with tightening screws on the sides of the connector.
Just make sure that it is firmly secured into both the ends.
If this doesn't work for you, please comment and let me know, and I will be more than happy to assist you to further resolve your issue.
I will appreciate your feedback and positive rating for this solution.
Thank you.
Where does place sell spertpart power suplay LCD Type 7317 17"
Most LCD monitors use the universal connection for power and video. You can go to any local electronics store and pick one up. It is a 3 pin somewhat trapezoidal connection. If you have a connection that is the circle with a pin in the center. You may have to order it from the manufacturer.
I have the compaq FP 7317 monitor and the speakers on it dont seem to work how can i fix it? i tryed plugging in other speakers but those work either
Make sure that your soundcard is properly installed as are it's drivers. Check to see that sound is not muted. This can be done via the speaker icon in the system tray or from sound in control panel.
Low volume on HP Compaq FP 7317.
You can try using an audio enhancer. That can boost your audio volume a bit.
Check out: http://www.pcauthorities.com/multimedia/how-to-boost-laptop-audio
Works for PC's as well as laptops.
Jules
Speakers
Sounds like you need to re-install your sound drivers.
Flickering screen
i had this problem & the circittree on the back of the monitor has a little ajustable screw if you ajust this till the flickering stops hope this helps
2answers
Compaq FP 7317 LCD Monitor
Check the buttons on your monitor for possible shorts. Sometimes pressing a sequence of buttons while turning the monitor on will lock the OSD.
Compaq FP 7317 Speaker / Sound Problem
Sounds like the sound card in your computer..
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
