there was a tech update on the swash plate housing, this along with the seal will need to be replacedthere was a tech update on the swash plate housing, this along with the seal will need to be replaced
You can't post conmments that contain an email address.
Precision measurement of lubricant is completely unnecessary. Simply apply a sufficient amount of lubricant to all parts to partially saturate all pivots and bearings without applying so much as to make a mess.
this machine uses an electrical solenoid to open the flow of steam from the heater..... the switch is in the hand trigger and the valve on the machine.... one of these is at fault
If you have a Karcher then you should always post your machines barcode. The karcher barcode is on a silver sticker and is usually 15 digits long. Example 156987400000123 is actually model 1.569-874.0 and serial number 00123....
exactement le même problème
I exchanged one after six months with an oil leak, now after eighteen months the replacement is leaking oil. Not happy.
