Karcher WV50 Window Vacuum Logo
Posted on Sep 25, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Karcher WV60 window cleaner will not charge. Actual charger not faulty any other ideas?
Level 3:
  • Karcher Master 18,429 Answers
  • Posted on Sep 26, 2012
Karcher Master
Level 3:
Answers
18429
Questions
Helped
1405224
Points
62248
It ma be the battery as gone dead
Hello. I have a Dyson dc59 and it will not charge. When I plug it in to the charger, a light blinks on the charger and the vacuum never charges. Help!
If you bought it new then you may get solution under warranty condition. Otherwise, you have to repair that from your local experts. As the battery is not charging but a light is blinking then I guess there some prob. inside the charging connection and battery or battery got damaged. Many possibilities there so best idea to make contact with repair man or you may but new one if the repair charge cost more from suppliers like "Vacuum Cleaner Helpers".
Not charging even though light shows it is!
It could be your charger mine does not work but it flashes all the time sorry I can't help you A.Rudd.
2helpful
Karcher wv50 spare on off switch
If you contact one of the Karcher Centers ( details are on Karcher.co.uk website) they may be able to help.
regards Gary
2answers
My karcher window vac does not seem to charge?
Have you tried to take it all apart just a small bit of rubbish will stop it from working.
2helpful
2answers
Why wont my karcher window vac switch on even after a full charge any ideas ?
Take it apart and see what is stopping it (the motor) from turning .
Karcher WV 50 faulty motor where can I get a replacement
look here
https://www.aliexpress.com/item/3V-0-2A-12000RPM-65Gcm-Mini-Micro-DC-Motor-for-DIY-Toys-Hobbies-Smart-Car-MOTOR/32950349790.html?spm=2114.search0104.8.4.74a81e90XHPlJW
9helpful
Can't switch Karcher window vac off
I had the same problem and I let the battery run down to stop it cycling on and off. My husband investigated it and found that there is a fault with the on board battery charge sensing circuit. (when the charge is about 10 to 15 % remaining the onboard ic controller cycles the unit on and off, irrespective of the switch. He checked it by cutting wires to the switch and it still cycled off and on so the switch was not faulty.
He put it all back together and said to charge it before it gets too low. If it cycles on and off it probably needs a re charge at that point.
Unfortunately there is no battery level indicator on the tool and nothing to suggest in the manual of what may happen when battery is flattening.
I am taking this up with Karcher as I only used it three times so far and it it was not a cheap gadget. Hope this helps
4helpful
DE4002 Steam Vacuum: Is there a manual for The Karcher DE4002 steam cle...
Hi There,
Here's a link to the owners manual for your Karcher DE4002.
If you found this information helpful, please be sure to rate the repair helpful, or leave feedback. This is really appreciated.
Owners Manual For Karcher DE4002 Steam Cleaner
Top Karcher Vacuums Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Karcher Vacuum Expert? Answer questions, earn points and help others
