HI,
you do need a new motor.you need to take 2 screws out of top where lint filter goes. take top up and their will be 2 screws one on each side take screws out and pull upward and forward and the front panel will come off. you will need to remove belt and tub then you will see motor. you will need to be able to grab back side of motor that attaches to blower and front shaft of motor and turn opposite way to come loose from blower. you will then take back clip off and front clip and unplug motor and pull out. good luck hope instructions helped.
thanks,
That is a wrong model but if it is a electric dryer. Unplug it. get to the back panel. take the 9-11 1/4" screws out. Locate the little white fuse. grab an ohm meter and check for continuity. if you dont have a meter then put the wires together and plug back in safely and try it. let me know if you need anything else. i have that fuse on sale here.
