Home | Kenmore | Dryers
Kenmore 62802 Electric Dryer
Problems with Kenmore 62802 Electric Dryer?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Problems
& Solutions
Manuals
& Guides
Repair
Service
Top
Experts
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Kenmore 62802 Electric Dryer RSS Feed
Click here to get instant support from our best Experts!
View More Results for Kenmore 62802 Electric Dryer
Questions and Unsolved Support Problems
Unsolved Problems for Kenmore 62802 Electric Dryer RSS Feed
Answer
I have a Kenmore Electric Dryer Series 80 Model 110.86980800 MX4737306. The heating element works -... (More)
Answer
I have same situation. Runs fine but does not heat. Yesterday, heated for first 10 minutes, then... (More)
Answer
I have the same problem - wont stop, just cycles threw all the setting until we open the door to... (More)
Answer
I have a Kenmore 80 series heavy duty x large capacity electric dryer.Twice in the past I have had... (More)
Answer
Select a cycle and it lights up...then nothing but a clicking noise when you hit... (More)
Answer
dryer times out after just a few minutes on both the moisture sensor and timed dry. The timer and... (More)
Find a Manual
Kenmore 62802 Electric Dryer Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
Tips & Tricks
(Post a New Tip)
Dryer Runs, but Does not Heat
This advice is for all ELECTRIC Dryers that have a "No Heat" problem. Symptom: Dryer turns on, drum spins, but you have no heat. Any of the... written by jsrock516
How to Install a Dryer Belt on Kenmore Elite and Whirlpool Duet Dryers
This advice is for dryer belt replacement on most Kenmore Elite and Whirlpool Duet model dryers. If in doubt, please provide me with a complete model... written by jsrock516
How to change your dryer from 3 wire to a 4 wire power cord. (short and...
Dryers come with a wire or metal strap connecting the center "neutral" terminal to the frame of the dryer. When using a four wire power... written by MNTECH
Washer and Dryer Repair manuals and Parts
Please rate a Fix Ya!!! Thanks jj505 For all Washers/Dryers/Parts http://laundry.manualsonline.com/ written by jj505
Possiable Manuel HELP OR ORDER PARTS LINK
Please rate a Fix Ya!!n Thanks jj505 http://www.repairclinic.com/Home.aspx written by jj505
SAVING TIME & MONEY $$$
To reduce the suction draft and drying time your drier and save some cash, remove the lint catcher and take it to the sink. Run water into it, if... written by DRRXR
Dryer operates but will not heat.
1. Disconnect electrical power to dryer. 2. Remove the lid. 3.On the front panel there is a circuit board (moisture sensor control board) with a six... written by gregorymholt
3-prong to 4-prong Power Cord Conversion.
This advice is on how to correctly install an ELECTRIC DRYER or ELECTRIC RANGE 220-240VAC power cord (US Standards). 3-Prong or 4-Prong ?... written by jsrock516
WikiManual
(Post a New Chapter)
How to Clean a Clothes Dryer Vent
If your dryer vent hasn't been cleaned in the past year or two, it probably needs it. There may even be a bird's nest in there. How do you clean... by wikihow
How to Wire an Electric Dryer
Modern appliances come with separate ground and neutral wires. Generally, this setup is safer, because the current-carrying neutral is not connected... by wikihow
How to Improve the Lifespan of your Clothes Dryer
Most of the problems in a dryer are caused by poor air circulation inside of the dryer. The dryer will suck air from the outside, pass it through the... by wikihow
How to Repair Loose Baffles in Your Dryer Tumbler
Do you hear clanking noises coming from inside of your dryer tumbler? It may be time to replace the dryer baffles. Here is how to check and go about... by wikihow
How to Prevent the Dryer Cord and Terminal Block from Burning Out
Tips on how to prevent the dryer cord and terminal block from burning out. Steps 1. The cause of the dryer cord wires and the terminal block for... by wikihow
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Top Repair Providers for 62802 Electric Dryer
Nationwide | 877-477-7278 | Website
Washer and Dryer parts delivered overnight nat... Read More
Featured Listing
Nationwide | 8003571234 | Website
Welcome to Action Appliance Repair. We have bee... Read More
Featured Listing
109 Olympia Way, San Francisco, CA 94131 | 415 5737868 | Website
1018 Valencia St, San Francisco, CA 94110 | 415 6418611
Commercial & Domestic Ranges
559 Valencia St, San Francisco, CA 94110 | 415 8615890
1290 Chestnut St, San Francisco, CA 94109 | 415 4743523
3063 Laguna St, San Francisco, CA 94123 | 415 3512554 | Website
San Francisco, CA 94127 | 415 2392800
3624 Irving St, San Francisco, CA 94121 | 415 2836424
5446 Geary Bl, San Francisco, CA 94121 | 415 7509077 | Website
* Residential & Commercial * Expert Repairs & Service Read More
Find an Expert
Meet our 2832 Dryer Experts
emissionwiz
Rank: GuruGuru
Rating:  90%, 7818 votes
Solutions:  14051 (813 Votes in the last 30 days)
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
miket756
#2: miket756
Rank: GuruGuru
Washers & Dryers ExpertExpert
Rating:  85%, 169 votes
Solutions:  632 (632 Votes in the last 30 days)
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
milten1
#3: milten1
Rank: GuruGuru
Rating:  90%, 439 votes
Solutions:  1303 (604 Votes in the last 30 days)
Experience: 15 years field experience and 5 years navy training
dmftrucker
Rank: GuruGuru
Rating:  88%, 336 votes
Solutions:  1459 (518 Votes in the last 30 days)
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
hunter19_46m
Rank: GuruGuru
Rating:  94%, 109 votes
Solutions:  609 (359 Votes in the last 30 days)
Experience: I have worked on many electric dryers in my working career. I am also mechanically inclined.
techbuster
Rank: GuruGuru
Rating:  90%, 433 votes
Solutions:  970 (344 Votes in the last 30 days)
Sassy6
#7: Sassy6
Rank: GuruGuru
Rating:  90%, 72 votes
Solutions:  367 (324 Votes in the last 30 days)
Experience: 20 yrs experience with appliances & Barbeques/Gas Grills
localwonder
Rank: GuruGuru
Rating:  92%, 2673 votes
Solutions:  4711 (317 Votes in the last 30 days)
Experience: I have yrs of experience dealing with many situations.
57 varieties
Rank: GuruGuru
Rating:  88%, 413 votes
Solutions:  1307 (308 Votes in the last 30 days)
Experience: I have been solving problems and fixing things for over 30 years!
drallim
#10: drallim
Rank: GuruGuru
Rating:  87%, 639 votes
Solutions:  1448 (283 Votes in the last 30 days)
Experience: schooling, on-the-job, just do it.
Find a Warranty
Specifications for Kenmore 62802 Electric Dryer
Key Features
Power Source
Electric
Load Type
Front Loader
Dryer Type
Home Dryer
Other Features
Cycles
9 Cycles
Cool Down Feature
With Cool Down Feature
Quiet Mode
With Quiet Mode
Energy Efficient
Without Energy Efficient
Moisture-Sensor
With Moisture-Sensor
Dimensions
Overall Depth
28 in.
Overall Height
43.3 in.
Overall Width (Display)
29 in.
Warranty
Warranty
1 Year
Kenmore Contact Information
Main support number1-800-KENMORE
Describe your problem:
Sponsored Links
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
