You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
SOURCE: Eager ****** not so eager when it warms up!
If the chain locks up it may be to tight. Try loosening the chain and see if the same problem happens.
SOURCE: need an owner manual for mcculloch eager ****** 300s-16
You would pay the manual about the price of new saw. These are made in china and usually motor or the switch blows. Check that the voltage pass thru the switch and if so and it dont work, throw it away.
Testimonial: "not what I was asking about. I wanted a user manual for mcculloch eager ****** 300s-16 electric chain saw. You people can't read."
SOURCE: Gas, Oil Mix ratio for McCulloch Eager ******
Fuel/Oil Mixture
Lou
SOURCE: I need an owners manual for McCulloch 100 series
McCulloch Manuals
Illustrated Parts Lists: (IPLs) are fairly simple, on the underside of McCulloch saws is a black and yellow tag; the upper number (“Power Mac 320” 600021H) is the model, below it a serial number (11-18555). These 2 numbers are combined to create an IPL number (“Power Mac 320” IPL number = 11-600021H). The IPL number can be used to find the correct IPL for every McCulloch parts supplier I have found. If the parts supplier only list part numbers the proper IPL is the source for the part number.
A complete parts list using the "IPL Number" can be found here:
K&T Parts House
http://www.mymowerparts.com/pdf/McCulloch_Parts_Service_Repair_Manuals/Gas_Powered_Chain_Saws/
Operators Manuals: are much more difficult. I have dialed this number many times (Contact Us - All McCulloch Products 1 (800) 521-8559) and have yet to get a satisfactory response. Please try this! If enough of us try they will fix it! If unsuccessful with McCulloch try here:
Beg for manuals thread (ArboristSite - free to join). Please use the search function first, it has probably been asked and answered.
http://www.arboristsite.com/showthread.php?t=72322 HTH
Lou
ArboristSite is where I found both my Mac 110 and Power Mac 320 operators manuals.
