20 Most Recent McCulloch Chainsaw Chain Saw Parts Piston Mini Mac 110 120 130 140 30 35 Questions & Answers
I recommend contacting your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
McCulloch... | Answered on Feb 20, 2018
Contact us
User manuals McCulloch Service
I trust this information proves beneficial.
McCulloch... | Answered on Feb 19, 2018
Most machines will have a z bend in the end of the throttle wire, the outer cable will be anchored with a square block into the induction block, the z bend in the cable will then fit into a hole in the throttle spindle on the carb, there will only be one hole in the spindle the correct size for the cable.
McCulloch Garden | Answered on Jul 09, 2019
Some carbs have obvious adjustments ("H" for high speed, "L" for low speed or idle. )
Some however are hidden. Heres a video showing how to find theses hidden adjustments.
https://youtu.be/tlsVcCdzaoA
McCulloch Garden | Answered on Jun 12, 2019
i don't know. please be careful. different oil used for air vs water cooled engines. if info not on engine near fuel filler, details should be in owner's manual or from boat engine retailer. also, new vs used motors may use different ratios.
McCulloch Garden | Answered on May 21, 2019
http://s30387.gridserver.com/partsDiagrams/McCulloch%20Late%20models.pdf
McCulloch Garden | Answered on May 16, 2019
Use the provided links:
Contact us
User manuals
McCulloch Service
McCulloch Garden | Answered on May 03, 2019
http://www.manualsonline.com/ This link m,ay have the manual that you are looking for,
McCulloch Garden | Answered on Mar 26, 2019
According to the manual, the gasoline to oil ratio for the Power Mac 320 depends on the lubricating oil. McCullough 40:1 Two-Cycle Custom Lubricant is recommended. However, any good SAE 40 two-cycle oil should be used at a 20:1 ratio.
See page 7 of the owner's manual. This is available from ManualsLib, https://www.manualslib.com/products/Mcculloch-Power-Mac-320-3983820.html . The direct link to the proper page is https://www.manualslib.com/manual/1011585/Mcculloch-Power-Mac-310.html?page=7#manual .
I hope this helps.
McCulloch Garden | Answered on Mar 25, 2019
McCulloch 10-10 - Chainsaws
www.mcculloch.com > McCulloch International > X-ref > Chainsaws > McCulloch
  1. Cached
  2. Similar
OLO017, 577616417, Chainsaw Starter Kit, 577616417. OLO002, 577616402, OLO002 - 2 Stroke Oil LS, 1000, 577616402. OLO004, 577616404, OLO004 ...
VINTAGE CHAINSAW COLLECTION: MCCULLOCH 10-10 MANUAL
vintagechainsawcollection.blogspot.com/2007/03/mcculloch-10-10-manual.html
  1. Cached
  2. Similar
MAC 10-10 MANUAL: ASSEMBLY NUMBER: 600005, 600006, serial prefix 10, 12, 16. YEAR INTRODUCED: August 1967. YEAR DISCONTINUED: May 1970
Setting the points is very easy. First you need to make sure they are flat and clean. One side gets a hole and the other side gets a cone. Use a diamond file to flatten them off. Setting the points is done at the widest point when you turn the engine. Where the piston is doesn't matter. Gap the points using a feeler gauge.
See these videos
https://www.google.com/search?q=mcculloch+10-10+chainsaw+manual+set+points
McCulloch Garden | Answered on Mar 13, 2019
McCulloch Chainsaw Chain Saw Parts Piston Mini Mac 110 120 130 140 30 35 Logo
Popular Tags
2 questions posted
Top McCulloch Garden Experts
roeb
Jay Finke
Jay Finke
John Trevino
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
View Most Popular
McCulloch Garden
  • McCulloch Garden
Most Popular Question
points gap mac 130 chainsaw
  • Garden
