20 Most Recent
McCulloch FH140A Electric Pressure Washer Questions & Answers
I had to take the
You can get parts diagram on-line on web site that will show you break down of parts that should help.
Nozzle clogged, can it be
Sometimes a high pressure air hose works. Sometimes but not always a paper clip can unclog them. I would try the air pressure first. Seems to work the best if your not going to replace them.
Mcculloch power washer fh140A 1400 PSI help
the unit will only **** up solution when the pressure is low, thats how they all work so you cant use pressure at the same time. You will notice that the pressure drops when using the solution ****..
soap 1st the pressure wash.
