Posted on Apr 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lanier LW324 waste toner bottle full
Our wide-format coppier says WASTE TONER BOTTLE FULL. i can't even find a waste toner bottle on this thing!! can anyone please advise as to where the waste toner bottle is located on the machine or how to rid the message. all production is stopped because of this! HELP!
Anonymous
Level 2:
New Friend:
  • Expert 63 Answers
  • Posted on May 01, 2009
Anonymous
Expert
Level 2:
New Friend:
Answers
63
Questions
0
Helped
39246
Points
116
Open the machine and to the right under the drum you should see the the black powder (toner) going down into container the right lower side  cover must come off. probably a service call will be needed
Waste toner bottle full so replaced but will not reset and says still full
then the clear section of the waste toner bottle is not clear some toner is left blocking the sensor that monitors the waste toner level
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Full waste toner bottle Lanier LD540C
The boys at the office figured out how to get out and empty... Thanks for all your input... I had sent it on to them.
1helpful
(6981A002AA) for imagerunner 2200, 2800, 3300 Print Server: I have also facing the same problem of Error code ...
So, you need to do next:
Because of statics and plastic bottle, the toner is collected on bottle neck, where is two circles. Even if bottle isnt full but the neck of bottle is dirty the error will occure.
Clean the neck with dry cloath, and then with some antistatic detergent, this will take care of the bottle.
But more permanent solution is to disconnect the waste toner sensor. You will see it above the waste toner bottle.Its a white connector with wires. Pull it out.
But then you need to take a very good care of amount of waste toner in bottle, because if it gets too full it could broke the waste toner gears. So that means that you must every time when you replace the drum, empty the bottle too.
Lanier 6720 U14 error on screen
U14 is a user code for waste toner full.
Open front cover and you will see a clear plastic bottle at the bottom of the machine; lift this out and dispose carefully of waste toner (do not reuse). When fitting back into machine, make sure that inside of bottle is clean as the detection sensor looks through the bottle to see if it is empty and if toner is covering inside of bottle, the message will remain.
How do i empty a waste toner bottle on a lanier color copier
What kind of copier is it? On many of the Lanier color copiers, the waste toner bottle is located on the lower left side inside the front door.
Turn the copier off first. Pull the big front door open and turn the bottle with the oil to the left -- the waste toner bottle is the plastic gray tank behind that. Slide it out (carefully) and dump it in a plastic trash bag, then reinsert it.
If you have a different kind of copier, please specify the model and I'll tell you how to get to the waste toner bottle.
2helpful
2answers
Where is the waste toner bottle located?
Remove the small cover on the lower left hand side( one screw only) and remove the waste toner bottle and emptied it ensure that bottle neck is not clouded with toner otherwise even the bottle is empty still it will detect waste toner is full .hope this will help
3helpful
2answers
Error code E000019-0000
This error indicates that the waste toner bottle is full
1helpful
2answers
Full Waste Toner Bottle in Lanier LD040
Hello sir; I believed you talking about LD045, am I right? In this model it doesn't have waste toner bottle, the only place you can clean is imaging transfer unit, after you cleanup the message will be disappear.
Lanier Copy Machine 3635
Is this a small table top model? They usually do not have a waste bottle. The waste toner accumulates is the drum housing Where hopefully the change drum warning will come on before the waste toner fills up and causes poor copies. I have taken the drum asm apart and vacuumed the toner out.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Top Lanier Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
