Question about Lanier 5235 Printer
Lanier 6720 U14 error on screen - Lanier 5235 Printer
Posted by dinobenedet2 on
ham6
    New Friend:
  • 3 Answers
U14 is a user code for waste toner full.
Open front cover and you will see a clear plastic bottle at the bottom of the machine; lift this out and dispose carefully of waste toner (do not reuse). When fitting back into machine, make sure that inside of bottle is clean as the detection sensor looks through the bottle to see if it is empty and if toner is covering inside of bottle, the message will remain.
Posted on Jul 26, 2011
I need to replace the screen but do not know how to open the case of my nokia 6720!!
I have attached a images of how to open the panel and remove the screen
Aug 10, 2010 | Nokia 6720 Classic Cell Phone
Bluetooth error Nokia 6720 classic and PC
I have the same problem on a toshiba computer
Jul 01, 2010 | Nokia 6720 Classic Cell Phone
Nokia 6720 sms notification not working
reset it n try
1. phone setting
2. reset factory default
3.code is 12345
4. after restart u choose profile n set the sms ringtone
Jun 02, 2010 | Nokia 6720 Classic Cell Phone
Why is my new 6720 not pairing with Parrot 3.18.
Switch-off your phone. 1. Press and hold 3
keys; Green dial key, *
Star key, no. 3 key on keypad and then press
the power on/off to
swtich on the phone. Remember, do not let go the 3
press and hold
keys until you see a formatting word screen show! 2.
After a few
minutes when the Full phone formatting completed, your phone
will
back to original system and factory settting.
Apr 16, 2010 | Nokia 6720 Classic Cell Phone
Lanier LD245 error code SC542 appears
Fuser warm up error. Code can only be reset in service mode after the problem is fixed
Jun 06, 2009 | Office Equipment & Supplies
Service code 561 error
Hello sir; Just follow my direction, it will reset your machine;
1, press "clear mode", "107", then press and hold down "clear/stop" key.
2, touch "copier SP" on the screen.
3, enter "5810-001" press enter.
4, set value to 0, then turn power off and back on again.
May 15, 2009 | Lanier Office Equipment & Supplies
Lanier 6720
If when you open the rt. door are the streaks on the drum unit? If not remove the 1 screw and slide the fuser out and check there
-Carl
Sep 03, 2008 | Lanier 5235 Printer
PANASONIC FA-A505
FA-A505 is the Automatic Doc Feeder number and not the copier model number. Without knowning the machine model number, This is just a general code for 95% of the Panasonic Copiers that use this code. If the U14 is flashing on machine, then check your waste container bottle for the toner. (Not the toner bottle, there should be a waste container that needed to be changed or at leasted emptied and then washed out with COLD water) Be warned.. washing the bottle out will make a mess out of your sink, so it is suggested to do in in a basement tub/sink.
If you do not have another waste container, then empty as much of the used toner in a plastic bag, and then rinse the bottle out. The bottle does not have to be completely dry when you re install it. Just shake as much of the water out as possible. If the U14 goes away, you are good to go. If the U14 is still showing, open the door and remove the bottle and see if you can close the door WITHOUT the bottle. If the U14 goes away, then the bottle is not clean enough. DO NOT RUN THE MACHINE WITHOUT THE BOTTLE, or you will have a mess in your machine. (some models will let you close the door without the bottle, and some wont).
Your best bet, is to replace it with a replacement container if your church has one and order some spares to keep on hand.
Hope this helps.
Good luck
Feb 02, 2008 | Office Equipment & Supplies
Printing problem with lanier 6720 printer
Check your photo conductor (drum) unit. This is often caused by an old or light damaged unit.
Sep 15, 2007 | Lanier 5235 Printer
264 people viewed this question
Top Lanier Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
George Mclaughlin
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
