Sentry Fireproof Safe Logo
Anonymous Posted on Apr 19, 2009
Opening problems i just bought a used sentry safe and i know the 3 number combination but im unsure of wich way and how many times to spin the wheel to open it?
Anonymous
Level 1:
  • Contributor 34 Answers
  • Posted on Apr 30, 2009
Anonymous
Contributor
Level 1:
Answers
34
Questions
Helped
12394
Points
77
Right 3, Left 2, Right 1.
2helpful
How do you open a sentry 1250 combination safe? I have the number
Locksmiths agree If your safe doesn't have a key, skip Step 3.
Turn the dial to zero.
Insert your sentry safe key and turn it until the plunger pops out.
Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
Turn the dial to the left to the last number (stop the first time on your last number).
Pull the handle down; cracking the Fireproof Sentry Safe open.
1helpful
NEED TO OPEN A SENTRY SAFE BUT DON'T KNOW WHICH WAY TO TURN AND HOW MANY REVOLUTIONS PAST NUMBERS SHOULD BE USED. i HAVE A OLDER SENTRY VALUE GUARD SAFE, MODEL # 1330
Locksmiths advise If your safe doesn't have a key, skip Step 3.
Pull the handle down; cracking sentry safe open.
4helpful
2answers
How to open Sentry V330 with combination and key?
3 Digit Combination Lock
31-10-31
  1. NOTE: If your safe DOES NOT have a key, skip Step 3.
  2. Turn the dial to zero.
  3. Insert your key and turn it until the plunger pops out.
  4. Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
  5. Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
  6. Turn the dial to the left to the last number (stop the first time on your last number).
  7. Pull the handle down; the door should open.
If this still does not open the safe, refer to the following page for additional different types of Sentry Safe models:
http://www.sentrysafeshop.com/kb_results.asp?ID=15
2helpful
Have Sentry 1250 safe. I have the combo but can't get it to work.
A1 locksmith will tell you.
2helpful
Forgot the code for my sentry 3110 safe
31-10-31
If this still does not open the safe, refer to the following page for additional different types of safes:
If you need to retreive your lost combination, you can get it at this link:
http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
Sentry safe ob0100 wont open with 3 digit com
A1 locksmith say's If your safe doesn't have a key, skip Step 3.
2helpful
Need assistance opening my Sentry 1250 safe. I have combination but do I start at 0 and pass the first number then stop 2nd time around at first number then go straight to the other 2 numbers?
Locksmith instructions for sentry safes
on how to dial open sentry fire safes.
NOTE: If your safe doesn't have a key, skip Step 3.
30helpful
5answers
I can't seem to unlock my safe Sentry 1250.
Also make sure you are executing the combination in the right steps... For mine (a three-number combo), these are the steps that work:
* turn the knob to the LEFT, pass 0 at least THREE times and stop at the first combo number
* turn the knob to the RIGHT, pass 0 ONCE and stop at the second comb number
* turn the knob to the LEFT and go directly to the third combo number (do not pass 0, do not collect $200)
1helpful
2answers
Sentury Fire Proof Safe 1250
Is there any way to crack the safe by feel, ive seen it done before and have some experience in opening locks with pin tumblers, but not wheel tumblers. i can find the notch in the third wheel at around 10-15 but i dont know where to go from there. I would not be using this information for any illegal use, i just need to open my safe on my own, and soon, thank you.
Top Sentry Home Security Experts
Grand Canyon Tech
Grand Canyon Tech
john h
ADMIN Andrew
ADMIN Andrew
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
