My dad has a 2002 Toyota Tundra and tows a 1996 Coachman Light Camper. His turn signals and brake lights work, but has no running lights. Is there a fuse on the truck specifically designated for running light, and if so, where is it?
Paul
Hey Paul, it's most likely a wiring problem. There is one wire designated for just the running lights. What type of plug does the truck have? Probably 6 or 7 way (6 or 7 wire). You can check the plug-in at the truck with a multi-meter to see if there's power at that point. If there is, then the problem is somewhere from the trailer plug to the lights on the trailer. If you have a 7 way plug, the center plug is for aux. power (back up lights on what you pull, if equipped). One wire is power to the camper battery for a breakaway switch, one for left turn and stop, one for right turn and stop, a ground wire, one for running lights, and one for trailer brakes. To determine what wire does what, 1st with meter check volts of all wires w/ truck and trailer hooked up, truck running, power wire to battery for breakaway should show voltage if equipped w/ a trickle charge, brake wire will show low voltage, approx. 2 volts, apply brakes and should go up to approx. 12 volts, put on L turn signal, meter should go up and down, as power to blinker pulses on and off, do the same to determine which is the R turn signal (put foot on truck brakes will show voltage to brake lights AND brakes, continue w/ process of elimination to determine which is running lights, and exactly where power is not going.
Accesory light fuses should be under the hood,check to make sure that the ground works for the trailer connector and also the vehicle connector.
4 way flat molded connectors allow basic hookup for three lighting functions; right turn signal / stop light (green), left turn signal / stop light (yellow), taillight / license / side marker (brown) and a ground (white).
4 way tow vehicle side.
4 way trailer side.
5 Way Systems
Same as 4 way system listed above but adds a extra blue wire for brake signal or auxiliary power. Used on pop up camper trailers or utility / boat trailers.
5 way tow vehicle side.
5 way trailer side.
6 Way System, Rectangle Plug
3/4 inch by 1 inch 6 way rectangle connectors right turn signal (green), left turn signal (yellow), taillight (brown), ground (white). The red and blue wire can be used for brake control or auxiliary. Use on a small motorcycle trailer, snowmobile trailer or utility trailer. Can also be used as custom wiring on trailers with 3 light/wire systems. See "Tow Vehicle Taillight Wiring" below.
6 way tow vehicle side.
6 way trailer side.
6 Way Systems, Round Plug
Round 1 1/4" diameter metal connector allows 1 or 2 additional wiring and lighting functions such as back up lights, auxiliary 12v power or electric brakes. Note: The black (sometimes red) 12v and blue electric brakes wire may need to be reversed to suit the trailer. Check with a test light or VOM. Uses: horse trailer, travel trailers, landscaping trailer, car trailer, etc.
6 way trailer side.
7 Way Systems
Round 2" diameter connector allows additional pin for auxiliary 12 volt power or backup lights. Uses: heavy duty landscaping trailer, car trailer, boat trailers, horse trailer, travel trailer, construction trailer, etc. Check with a test light or VOM.
7 way RV flat blade tow vehicle side.
7 way RV flat blade trailer side.
