I have an EnV phone and an LG HBM-730 headset. The headset was programmed with my old EnV, but when it broke and I got a new one I didn't have the directions to program it. Can you help me program the headset to my new EnV phone? thanks.
SOURCE: I can set up my headset to my new phone
These are from verizon wireless.com. Support Phones & device Choose phone Choose device Help topics How to pair handset to headset
SOURCE: Bluetooth HBM-730
just set the bluetooth earpiece to pairing mode and start searching bluetooth devices from your phone.
If you don't have a manual, just post back.
SOURCE: How do I set my Bluetooth Headset HBM-730 to discover mode?
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.
2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select HBM-730 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
SOURCE: I have an LG EnV that will pair but not connect
Try removing the battery of the phone while the phone is powered on. Replace the battery, power on the phone, and try to re-pair your phone.
