Only can hear minimal noise out of front speaker in stock delco CD/radio. What is the problem internal amp?
SOURCE: 1989 Chevy Truck , Stock Radio , Whining noise
Sounds like you have a capacitor problem.It could be a number of issues , but i suggest you check the alternator one first.
If you unplug the power cable to the back of the alternator and the whining goes away then replace the capacitor(usually only one bolt/screw)and you should be OK.
If not I sometimes have dissconnected the + wire from the HT coil when the car is running and the same applies,and if this works replace the capacitor or fit one if there isn't.
If none of this helps fit one to the + wires of your radio.
Please leave fair comment if I have helped you.
Thank you
Testimonial: "This is Great Info, I'll try all ideas . Ross "
SOURCE: Delco factory Radio/CD player,it gives an err msg.and ejects CD
The laser in the cd player may be dirty or has gone bad and can no longer read the disc.
SOURCE: 2004 truck delco radio 5 disc cd player. cd
Common for the CD to get stuck on the Delco radio, Try resetting the radio by disconnecting the battery for 5 min and then reinstalling the cables. This will reset the radio and you should get your CD to work again, if there is an issue. You going to have to go to the dealer and they are going to have to use a Tech2 scanner to reset and reprogram the radio. If there is any mechanical issues the Tech2 scanner will identify the issues, but 90% of the time. It's just a simple reset and the other 10% is a reprogram or replacing the unit.
Thank you for using fixya and good luck.
